Posthole Digger PTO post hole digger Vs Hydraulic Post hole digger
   / PTO post hole digger Vs Hydraulic Post hole digger #1
kcook
Platinum Member
MI
Cub Lawn Tractor
What is the advantage of both and disadvantage of both?
Any thoughts?
KC
   / PTO post hole digger Vs Hydraulic Post hole digger #2
Hyd costs 3x or more - big disadvantage.
It is more forgiving - won't shear as many pins as the hyd will bypass if you hit something unmovable. As well you can reverse the auger if it gets snagged - need to use a pipewrench & do it manually with a pto unit.
--->Paul
   / PTO post hole digger Vs Hydraulic Post hole digger #3
I have both, but I am adapting a Worksaver hyd PHD to
my backhoe, which gives it much more flexibility. It can also
be used on a 3-pt frame. The cost of the Worksaver 714H is
about $1500, and the HD mechanical 3-pt unit (# 500) is about $550, without augers.
   / PTO post hole digger Vs Hydraulic Post hole digger #4
Need to make sure you have the required flow. A hyd phd is a little more expensive than a QUALITY pto unit, but is reversible, and self centering which is great for deep holes(3pt trajectory) and hilly ground. Most are fel mounted which saves the neck. A hyd is a bit more complicated and requires power beyond and extra valve. Mine has a 12v directional valve wiring to worry about. I thnk a hyd will handle a larger bits like my 24" amd 36". Ive never tried them on the pto auger as they don't fit.
   / PTO post hole digger Vs Hydraulic Post hole digger #5
I have a Greenline EM5000 3-Pt PTO-driven PHD for my JD4600. This fall I drilled over 150 holes (1300ft on 8ft centers - 3 ft deep) for my perimeter PVC 3-rail fence and other than minor issues with some rocks, the drilling went without major hiccups. The cost was reasonable - purchased through my local JD Dealer - and is comparable to what one would buy a Speeco unit through TSC for. Naturally it requires that you be a bit more careful when drilling as the downward pressure isn't there (unless you have the hydraulics back there), but it did a good job for me. I am going to install another 750-1000 ft of fence this next year and aside from having sheer pins available, I believe this to be just fine for my use. I quite frankly don't know why I'd need the hydraulic unit otherwise..... /forums/images/graemlins/confused.gif
Good luck with your selection!
-Bob
2008 DOOSAN G25 GENERATOR (A52472)
2008 DOOSAN G25...
SEET BOX W/ CABLE SLINGS (A54757)
SEET BOX W/ CABLE...
2013 Cummins ISL G 300 8.9L 6-cylinder Turbo Diesel Engine (A55851)
2013 Cummins ISL G...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A56138)
2018 FREIGHTLINER...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50323)
BW RVB3405...
John Deere 5103 (A53317)
John Deere 5103...
