Tommy, I have tried to hold the control lever in gear with the bush hog attached. the pto will start to turn then jump into neutral. I can then put the lever into the high speed and it runs fine. I had been using The bush hog in low speed before this started occuring. What is so strange is that if an implement is not attached I can put the PTO in low speed and it turns just fine. Do the PTO shaft gears ever get stripped?
