PTO Pump
/ PTO Pump #131
2006 7520 Hyd Pump. Hose at pressure coupling goes to pressure gauge.
4174
4175
Dont know why these wont open
Thanks Dougster!
/ PTO Pump
Dougster said:
Hi Larry - Those great hi-res pix you just posted clearly show (once magnified) the same number: "50121509" on both pump sections... presumably a serial number or model series number of some sort. But the interesting part is the other set of numbers: "4028" and "4085"! I'll bet anything those numbers relate to either cavity dimensions or displacement... in metric units no doubt... or perhaps a specific pump component number.
Now I've just got to find the "link" to what's offered out there by Eaton. :rolleyes:
Dougster
I may have fallen off of a turnip truck, but I didn't fall off of a turnip truck last night. What photos? :confused:
hugs, Brandi
/ PTO Pump
Dougster said:
Wet clay is certainly heavy... especially when dealing with a 36" bucket and possibly marginal flow for a 511 for now... but is it all about the weight? Or is there a bucket "suction" problem here too? :confused: I sense the latter plays a significant part.
It is a 24 inch bucket piled up about the size of the bucket, so it is over a bucket and 1/2. Also, it is not mud suction, as the more I hoe in the stick, the higher the boom can lift it.
hugs, Brandi
/ PTO Pump #134
Brandi, click photos at the top of the page. Theyre there but I dont seem to be able to attach them to a post so they will open in the post.
larry
/ PTO Pump #135
SPYDERLK said:
MtnView. I dont think you have an suction leak since you reported no jerkiness ever.
Assuming your loader is exactly the same as mine I could probably give you a pretty good number if I assume there is no waste of pressured oil in the equalizing scheme. If you want to report the full amount of travel of your lift cyls and related extension of you (un) curl cyls during a raise, then the tolal fluid use would be calculable - and hence gpmvstime. Doing this with mine would require more work up and down ladder to duplicate bucket angle.
larry
Larry, I will get those measurements for you in the future, may be a few weeks, got to many irons in the fire right now. Thanks for the offer to do the calcs.:)
/ PTO Pump #136
larry
Larry, how does one go about fixing a suction leak?
/ PTO Pump #137
I took apart the whole suction path, while is a "tube" running from the sump to the pump. There are several flanged joints in this circuit for filters, rubber couplings between rigid pipe, plugged ports for optional gauging, etc. Everywhere theres a joint is a leakage possibility. I found many suspect places. It took a while to address them all. I seem to have no leaks now. Faster FEL - no jerkyness after sitting, higher free flow pressure shown on the gauge I added to the hyd pump output port. Last means more flow thru whatever restriction is inherent in the pressure side under free flow. Im seeing 700psi at 2500rpm fully warmed. Thats 7HP going to waste at full revs.
larry
/ PTO Pump
Well, today I passed 100 hours. :) Now I can crank the rpm up when hoeing. :D I had it around 2100 rpm today digging up 5-6 inch oak and youpon and had to slow the swing knob a turn or two. :cool: The 24 inch bucket was just taking one scoop to uproot this size tree. Tomorrow will try higher rpm while cleaing a fence row.
hugs, Brandi
/ PTO Pump #139
hugs, Brandi
Those poor Texas trees don't have a chance now! :D Enjoy the higher RPMs and higher flow... and let us know how it goes! :) We need a full report! :cool:
Dougster
/ PTO Pump
Dougster
Dougster,
The trees have hired the summer rain storms,so they have a repreive. :( We have had over 4 inches this month already and June was even wetter. :eek:
Just give me two days of sunshine...................:D
hugs, Brandi
TAKEUCHI TL6R SKID STEER (A59823)
TAKEUCHI TL6R SKID...
1973 White Trucks Western Star Dump Truck (A61165)
1973 White Trucks...
2004 FORD F-350 XL DUALLY CREW CAB FLATBED TRUCK (A59823)
2004 FORD F-350 XL...
2012 ISUZU NPR CREWCAB 16FT BOX TRUCK (A59905)
2012 ISUZU NPR...
40' 6 Door Shipping Container (A60352)
40' 6 Door...
2018 ADDCO ROAD SIGN DH1000-ALS (A60736)
2018 ADDCO ROAD...
