PTO Pump
/ PTO Pump
Ok guys, I ran my 6520 around 2250 rpm today. That BH cut through the sandy loam and clay like butter. It was sweet, but a long dig as it was a very large oak and had to dig down around 8 feet all the way around it. I kept having to turn down the swing speed know. :D
hugs, Brandi
/ PTO Pump #142
bindian said:
Ok guys, I ran my 6520 around 2250 rpm today. That BH cut through the sandy loam and clay like butter. It was sweet, but a long dig as it was a very large oak and had to dig down around 8 feet all the way around it. I kept having to turn down the swing speed now. :D
hugs, Brandi
So is the final verdict in? To PTO or not to PTO... that is the question! :) Or in your case... to possibly upgrade (after warranty runs out, of course!) to a monster 7520 pump. I've got to believe you are now well up into the 9-12 GPM range recommended by Bradco for the 509/511 backhoes. Can you live with working at that engine RPM? Did you put your earplugs in? :D
Your machine (The "Big Red Beast" - non-turbo version) is rated at 11.4 GPM. My machine (Now known as the "Half Red Beast" by comparison) is apparently now rated at 9.5 GPM. Exact engine RPMs corresponding to those two published ratings are still a point for debate. But I'm still thinking that I am a little shy of what the 509 could really do with flow at the higher end of that range and even more... approaching the reported bypass setpoint of 14 GPM. That's what my (currently oversized) gut is telling me.
Someday, I would love to try a 509 or 511 with a PTO pump installed... and I mean a good sized pump. Don't care if the bypass cracks open... I'd really like to know what this BH can do with some serious hydraulic flow. :D
Dougster
/ PTO Pump #143
Dougster
I'll second that!
/ PTO Pump
Dougster
Dougster,
It is not the noise, but all that heat coming up around the steering wheel. Not to mention after digging the big stump out last weekend, the cylinders were to hot to touch very long. For now, a pto pump or a pump oof of a 7520 is a low priority.
hugs, Brandi
/ PTO Pump #145
bindian said:
Dougster, It is not the noise, but all that heat coming up around the steering wheel. Not to mention after digging the big stump out last weekend, the cylinders were to hot to touch very long. For now, a pto pump or a pump off of a 7520 is a low priority.
hugs, Brandi
Sounds like you may be approaching the practical limit of what a removable, tractor attachment-type backhoe can do! :) You've got to start choosing smaller stumps! ;) Or is it time to buy yourself a big yellow commercial backhoe??? :eek: :D
Clearly, on your machine, a carefully selected PTO pump would enable you to reduce engine RPMs, engine noise and engine heat... but you could end up with a hot BH seat right over top of the PTO tank and pump. Some have complained about hot vapors... not sure I would like that. The 7520 pump upgrade would enable you to achieve the same higher flow (at lower engine RPMs) tending to solve the engine heat problem with no PTO pump nuisance issues. Of course, there *is* the new tractor warranty issue. :rolleyes:
I guess I'd want to know how hot those hydraulic cylinders are really getting and whether it's a real problem or completely normal. Time to get an infrared temperature gun? And I've asked this before: Is a hydraulic oil cooler practical on a tractor? :confused:
Dougster
/ PTO Pump #146
bindian said:
Dougster,
hugs, Brandi
they sell heat exchangers for hydraulic return lines. If you've checked everything else out, such as relief valves and new filters and fluid maybe it is time for plumbing a heat exchanger (radiator essentially) inline. Another option is adding a secondary hydraulic reservoir to boost hydraulic fluid capacity. This is supposed to keep it cooler as well as the oil has more time before reuse.
/ PTO Pump #147
You know, I thought you guys were paying attention when I mentioned that the PTO pump that comes with the Bradco 511 does a wonderful job at about 1200 engine rpms (don't need no stinkin' earplugs nor insulation from engine heat). I've had to turn down the swing knob to almost closed and I can still make it go pretty fast. Loam???What's that?? I live in VA where its either red clay or "green" clay--stuff is impervious to anything. Like I said, the PTO pump without any special stuff, using the Bradco setup (including the hydro oil tank) will give you all the power you can use at a very low engine rpm. I guess you can believe me or go get some other setup to your liking. NOTE: After about 2 hours of hard use the oil tank is about 100 or so degrees--so you won't be cookin' your butt anyway. BobG in VA
/ PTO Pump #148
You did mention that... which confused the heck out of me, but only because I haven't a clue what pump model or pump specs we are talking about here. Not sure at what engine RPM your 540 RPM PTO actually hits 540 RPM... but I'm assuming it is around double the 1,200 RPMs you run the engine at to accommodate the 511 backhoe. That means the PTO pump is really turning at maybe 270 RPM to give you more than acceptable performance. Assuming this is putting you at the high end of the 9-12 GPM Bradco specified range... that means your PTO pump must be a ~24 GPM (or greater) rated pump at 540 RPM. This really wouldn't surprise me all that much... but I am not sure such a pump would work very well on my somewhat smaller 4110 given that at 270 PTO RPM I may not be producing enough net horsepower to smoothly run a hydraulic pump fully-loaded at 12 GPM.
The bottom line is that it would really help to know exactly what you are getting for a pump in that Bradco PTO pump kit.
Dougster
/ PTO Pump
Bob,
Loam or loamy soil is a mix of clay and sand. It packs good and holds more moisture to help it pack better than sand. But is easier to work than clay. It works great under contrete as a base or under gravel for a driveway
If I used the BH hot and heavy every day, I would look into cooler options. But right now, I need to finish my barn. Dougster has distracted me with talk of hydraulic thumbs and grapples. :) The rain is gone and now it is barn siding time.
hugs, Brandi
/ PTO Pump #150
Dougster
The 6000 makes PTO speed at about 2050rpm. I understand from Bradco/Mahindra that the pump puts out about 14gal min. (hence the tank is sized for that...I think it took me about 13 gallons to fill it to the right level). Again I have the option to shift over to 1000PTO and lower the tractor rpm lower, but why bother, as the diesel needs some rpm to not lug. BobG in VA
UNUSED FUTURE 32" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 32"...
2015 Nissan Altima SV Sedan (A59231)
2015 Nissan Altima...
2006 KAWASAKI BAYOU 250 ATV (A60430)
2006 KAWASAKI...
2020 PETERBILT PB337 SERVICE TRUCK (A59823)
2020 PETERBILT...
2025 Miva VA13 (A60463)
2025 Miva VA13...
2010 Ford F-150 Pickup Truck, VIN # 1FTEX1CW9AFC54781 (A61165)
2010 Ford F-150...
