PTO Reverser Kit
   / PTO Reverser Kit #11
When Hub City sold them, they went for $600 to $700. They were discontinued two years ago. The reversers weighed about 20 to 30lbs., measured roughly 5.5"x8" and had a c-c measurement of 3" between the input and output shafts. The internal ratio was 1-1. Gearing consisted of heat treated alloy steel spur gears.
In the last years, the units were built only on order. There were no parts kept in stock.
   / PTO Reverser Kit #12
Darren, why in the world would anyone manufacture, (or buy), a tractor with a counter-rotating PTO. Is there a special purpose, or any implements available for them?
   / PTO Reverser Kit #13
Who knows? Why do the British keep driving on the left hand side of the road? If I was to guess, maybe the B6000 is a gray market unit. There would have to be impliments made for it. They might be a bit scarce here. Some impliments, like mowers, maybe you could turn the blades over and run in reverse.
   / PTO Reverser Kit #15
Buddy of mine had one, and he basically reversed every attachment that he used with the tractor. Finish mower he re-routed the belts and added spring loaded tensioners. He built a small box blade, a rear blade and was working on a bush hog when he came across an Allis Chalmers B model and decided to sell the Kubota. If I remember correctly, blade direction was the only issue with the bush hog, which just requires finding reverse cutting blades.
I also remember something about the pto shaft not being standard size... maybe 18 mm or something????
David from jax
Adams 5 ton Fertilizer Buggy / Wagon (A46877)
Adams 5 ton...
Trash Combo Trailer (A45336)
Trash Combo...
Predator 212 CC Small Gasoline Engine (A47484)
Predator 212 CC...
2008 Hyundai Tiburon Coupe (A44572)
2008 Hyundai...
2006 Komatsu PC27MR-2 Mini Excavator (A44571)
2006 Komatsu...
2017 INTERNATIONAL LF687 (A45046)
2017 INTERNATIONAL...
