PTO Shaft Balance
   / PTO Shaft Balance
Thanks for the replies. I have alot to learn and this site seems to be the place along with seat time. I really strive to take proper care of my equipment and want it to last.
   / PTO Shaft Balance #12
If the PTO shaft is used, check to be sure it's not bent slightly, it happens more than you might think. Mine got bent a while back and had more run out than it should. You'll have to remove the shaft covers and end guards to check it, I ran mine briefly without them in place to be sure of how much run out there actually was.
I ended up replacing the outer shaft, it was pinned in the universal yoke and could be separated without too much trouble.
Sean
   / PTO Shaft Balance #13
Sean
I had one that was slightly bowed. It doesn't take much to make it difficult for the shaft to extend or retract. It's still setting in my outbuilding, I think.
BTW, don't forget to pull them apart to grease 'em once or twice a season.
   / PTO Shaft Balance #14
Welder1, just as a mention, when activating the PTO do it slowly but deliberately. This will make things a little easier to start for your tractor as well as the cutter.:thumbsup:
   / PTO Shaft Balance #15
Very important info above. Engaging the PTO at a lower RPM (1200-1500) reduces the shock load on both the tractor and the cutter. Much easier if you have a gear tractor, BTW.
Some hydro machines' PTO is on or off...no feathering as you can do with a gear tractor, unfortunately.
   / PTO Shaft Balance #16
Are you trying to start another gear vs hydro TBN war? Not that I am against it. Always fun reading.
   / PTO Shaft Balance #17
Not at all...
Engaging a cutter requires a bit of finese...a "soft" start might be a good description.
Engaging at 1200-1500 RPM may cause the tractor to stall. If the operator has a hand or foot throttle, he can keep it running. Slipping the clutch (this assumes a live PTO, not independent) can ease the start.
   / PTO Shaft Balance #18
I let the engine idle and slowly engage the PTO clutch to spin up the hog, than let the clutch out slowly to move the tractor and then bring the engine speed up to PTO speed. :thumbsup:
   / PTO Shaft Balance #19
Agreed. My John Deere has an either "on or off" PTO switch so no feathering while my Kubotas have lever engagement which allows feathering. (the new models may be different) My L5030 also has a clutch which also disengages the PTO, so I will depress the clutch lever, fully engage the PTO lever and then feather with the foot clutch. Now I don't like a clutch on an HST model, but it's there, so I use it. Now my geared Case has a slot half way through engagement where you stop for several seconds to let the PTO spool up and then you engage fully and this works great. You don't have to touch the clutch and can engage while underway.
Feathering, no matter how it's done sure makes mowing easier on the equipment and nerves, at least for me.
Manac Walking Floor Trailer (A50322)
Manac Walking...
7pc Mini Excavator Attachment Set (A51573)
7pc Mini Excavator...
2020 John Deere 8R 410 MFWD Tractor (A53342)
2020 John Deere 8R...
2021 VemaTEC 30in Excavator Bucket (A51691)
2021 VemaTEC 30in...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
2025 New/Unused Wolverine 3 Point Quick Hitch (A51573)
2025 New/Unused...
