PTO Shaft Issue with Shear Bolt
   / PTO Shaft Issue with Shear Bolt #21
Get the orc for sure.. install it on the tractor end. If you have room on the mower side, and want a slip clutch.. get it. Make sure you have adequate pto shaft clearance when open and closed... I'm guessing you will have to cut it down.. just remember.. measure twice.. cut once.. and take equal amounts off each side, including the shields..
If you decide to go with 1 only.. get the orc.. and then stick to soft shear bolts..
Soundguy
   / PTO Shaft Issue with Shear Bolt #22
Thanks Soundguy! I am somewhat confused by the terminology you used in one place...
" Make sure you have adequate pto shaft clearance when open and closed..."
It is the "open and closed" part I don't understand. What is this referring to?
Thanks again!
Greg C
   / PTO Shaft Issue with Shear Bolt #23
PTO driveline are comprised of shafts within shafts. To extend is to "open", to compress is to "close". In both cases, there will be some of the inner shaft protruding from the outer shaft.
The point at which the shafts are completely compressed is when the implement is lifted to a height that puts the tractor PTO spline and implement transmission shaft on a parallel plane. At this point, there should be at least one inch of the inner shaft protruding. Closed. When the implement is then lowered to it's working position, the inner shaft extends to it's working length. Open.
//greg//
2019 F150 (A61306)
2019 F150 (A61306)
Pace American MW8516TA2 T/A Enclosed Concession Trailer (A56857)
Pace American...
2007 Sterling L7500 Terex Commander C6060 T/A Insulated Derrick Digger Truck (A60460)
2007 Sterling...
excavator trenching bucket- one bucket per lot (A61306)
excavator...
1959 DODGE D510 DUALLY FLATBED TRUCK (A59823)
1959 DODGE D510...
2012 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A59904)
2012 FREIGHTLINER...
