PTO Stencil
/ PTO Stencil #11
Jim -- That is very cool and it's very generous of you to share. I know of a public library that has a 3-D printer people can use.
I can't believe some are giving you a hard time about this.
/ PTO Stencil #13
PTO on the Kubota M9540 has a brake on it as long as there is hydraulic pressure /engine running. Shut the tractor off and it spins freely.
/ PTO Stencil
Thanks,we have a IH 90C and a IH 5130 and of those lock the PTO ON or OFF. But the stencil is still useful as you can now see where the splines are.
--jim
/ PTO Stencil #16
Yep, and that engine should be off before attaching any PTO implement!
/ PTO Stencil #17
Hi,
I always have trouble attaching a PTO shaft with a tractor that has a locked PTO and some heavy equipment like a haybine or tiller where you cannot easily turn the shaft. The major problem is you cannot tell where the splines are on the female coupler. Attaching this is a 15-20 min greasy job with lots of frustration. I have designed a 3D printed plastic stencil that lets you paint marks on the end of the coupling so you can see where the splines are and see where to move the shaft as you do the attachment.
Attached is a ZIP file that has a document explaining further and source for the 3D part and an .STL file that can be sent to a 3D printer.
If you need any further info write me at jim.schimpf@gmail.com
Very cool Jim, thanks for sharing!
2018 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A60736)
2018 DRAGON 150...
CAT 289D3 (A58214)
CAT 289D3 (A58214)
2017 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2017 Ford F-150...
2016 Ford Explorer AWD SUV (A59231)
2016 Ford Explorer...
2018 Isuzu NPR Cab and Chassis Truck (A59230)
2018 Isuzu NPR Cab...
2014 Bolens 11A-020W765 20in Push Mower (A60352)
2014 Bolens...
