PTO stopped working
   / PTO stopped working #11
Sorry to hear, as has been mention wires or possible a fuse or relay.
GoodLuck
   / PTO stopped working #12
Did any wires get pulled off when you were mowing.... :confused3:
Agree this could be as simple as an electrical 'disconnect' if hydro fluid is up to snuff with all cyls 'in position per manual'.
Reason I mention is 'electro-hydraulic' PTO on this model. Gee, I hope it's that simple.
   / PTO stopped working #13
Check the fuses... and did you shut everything off and start over maybe a switch or lever is not engaged properly ..... I'm lost you might have to call the dealer...
well we have no idea....manual is useless.....as is our dealer
yep did that, and all levers have been disengaged and re engaged....manual is useless...as is the dealer....who is 3 hours away and wont reply to emails or calls or txts.....and like i said, its only done 38 hours .....so livid
   / PTO stopped working #16
Maybe try in Auto?
   / PTO stopped working #17
If you disconnect the pto shaft can you easily turn the tractors pto shaft by hand (with the tractor off) first at least.
   / PTO stopped working #18
If its like the Branson system, the position of cylinders won't make a difference... unless the PTO switch is in "auto" position, which means the PTO switches on when the 3pt is lowered and switches off when it's raised.
The Branson PTO hydraulics that provide pressure to the PTO clutch run off the steering's hydraulic circuit. I don't know if TYM does the same but it's likely.
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
2006 iDrive...
2018 ALLMAND MAXI-POWER 45 GENERATOR (A58214)
2018 ALLMAND...
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
2012 Ford F-250 4x4 Pickup Truck (A60460)
2012 Ford F-250...
iDrive TDS-2010H...
2012 KINZE FLAT FOLD ROW MARKERS SET FOR 12 ROW 36/38 STACK FOLD TOOL BAR (A55315)
2012 KINZE FLAT...
