PTO won't disengage
   / PTO won't disengage
Hello CobyRupert - I had a topper on it a while back and I could not get it to stop rotating - I have seen and heard about PTO accidents so have no intention of going any where near it whilst the engine is running - not nice to be wrapped around that! Thanks
pto controls 1.jpgpto controls 2.jpgpto controls 3.jpg Here are some photos of the PTO control and cab controls
The manual I have is not quite the same as the controls - it shows a three position control with Neutral being in the centre, but I only have two positions for it to work in.
2 pososions...engage and disengage WITH at the back a choise of 540/ 1000 ?
Well that is an interesting question - at the back there is a small pull lever which seems seized at the moment - I have sprayed with WD40 and left to see if it will free up, but there is no mention of what it does in the manual, and I don't know where else a speed change control would be...
   / PTO won't disengage #18
Next....can you remove the inspection cover at the bottom of the bellhousing and take a photo of the pressureplate...mybe we can see if you have a ipto clutch or a dualstage clutch ?
2023 Kubota KX057-5 Compact Excavator with Angle Blade (A55314)
2023 Kubota...
2011 GALYEAN 130BBL VAC TRAILER (A52472)
2011 GALYEAN...
Chevrolet Metal Tailgate Art (A55853)
Chevrolet Metal...
2000 Kenworth W900 - 3406E CAT Engine - 78,980 Miles (A55302)
2000 Kenworth W900...
2017 Ford F-150 Crew Cab Pickup Truck (A54814)
2017 Ford F-150...
