PTO won't engage
   / PTO won't engage
Re: PTO won\'t engage
No PTO selector. Just a pull/push knob on the right side beside the 3pt up/lower slide control.
I just removed the backhoe from the tractor. I grabbed the PTO shaft to turn it, but it only turns a little bit then "clink" like there's a stop internally, preventing it from turning anymore. It also "clink" going the opposite direction.
BTW here's a pic of the backhoe on the JD.
pic
   / PTO won't engage
pic
   / PTO won't engage #13
Here's the phone number I used to order my CD manual: 800-522-7448
Ralph
   / PTO won't engage #14
Ralph
   / PTO won't engage
Thanks for the number. I'll call tomorrow and order one.
BTW is the repair manual in a CD version better than one in hard copy? Is it "user friendly"? Just curious... Thanks
Seon
   / PTO won't engage
Seon
   / PTO won't engage #17
I just worked on my JD 4410 and had a bad solenoid on the dirverter. Its called a control valve. The front one goes to the 2 wheel drive switch. The rear one goes to the PTO. My PTO one had 11.1 ohms resistance and was good. My 2 wheel drive one was 0 ohms, and had gone to ground blowing a fuse. I paid $33 for the control valve and took about 30 mins to replace it. You can just unplug the wires and check resistance without taking it off. Hope this helps. /forums/images/graemlins/wink.gif
   / PTO won't engage #18
   / PTO won't engage
Where's the solenoid located? I don't have a manual to use as a reference.
Thanks
   / PTO won't engage
Thanks
UNUSED Tool Set (A53117)
UNUSED Tool Set...
2019 Bobcat 3400 4x4 Utility Cart (A51691)
2019 Bobcat 3400...
1999 MACK RD688S MIXER TRUCK (A55745)
1999 MACK RD688S...
ASSORTED NYLON SLINGS (A54757)
ASSORTED NYLON...
Towable Diesel Fuel Tank with Pump (A53421)
Towable Diesel...
(INOP) FORD 7710 TRACTOR (A51247)
(INOP) FORD 7710...
