PTO
stray
Platinum Member
east TN
Power-trac 422 2003 model and 428 January 2015 model
Guys. I had a failure. Help needed and appreciated!! What is this and what does it do?
Don't know. Looks electrical. Is it on your PT422? Where is it located exactly? What engine is it?
It looks like a voltage regulator to me.I know that the Kohler regulator is mounted on the engine.
Looks similar to the voltage regulator mounted in my PT-422. Mine is mounted on the PT frame near the starter. It is about $25 for the 15 amp replacement. /forums/images/graemlins/smile.gif
Dale
If that is in fact your voltage regulator, it could just be defective. I would disconnect those wires from the regulator, and start the engine and check to see if you have about 26 volts AC from two of those wires. The other wire should be the 12 volt DC battery charging wire with a good regulator. If you don't have the 26 volts, then the alternator is bad.
/ PTO
Thanks guys this seems to be my findings. I guess $25 won't be too bad. The old one is completely burnt out. I had had trouble keeping the battery charged on my 422 but didn't find this problem till the PTO wouldn't switch flow to the PTO hoses. I started looking and thought this burnt out thing was the problem. Not!! This was another problem.
The machine would only do the grunt thing when I turned the PTO switch on and act like nothing was hooked to the hoses. After calling Terry of Power-trac I took the nut loose on the solenoid mounted to the block, (as I said different problem) twisted and pecked around on it, put the solenoid back together. The PTO was fine after that.
PS. Terry said only tighten the nut on the solenoid to 10 ft. lbs. (not to tight).
Now after this I will be able to use my PT as long as I keep the battery charged. At least till I get a voltage regulator and make up some new wires that the insulation was burnt off of.
Thanks again for the help and I hope this discussion goes beyond helping me and adds to the already large value of this forum.
I had a similar problem two years ago with my PTO solenoid. At the same time I had a 30 amp voltage regulator, original equipment, that kept going bad. My PTO solenoid problem did not go away after I solved the voltage regulator problem. I assume the ignition switch would heat up and dropped the voltage to the PTO solenoid. Rather than replace the switch, I installed a wire with a fuse from the battery post on the starter to the PTO switch. No more PTO solenoid problems. Yes , the PTO solenoid switch will remain energized with the ignition key off. I kept the wire from the PTO switch to the ignition switch that prevents the engine from starting with the PTO switch ON.
Hope this helps,
Dale
For safety reasons, I would have thought that the solenoid voltage would have come from the accessory terminal on the switch.
/ PTO
I was wondering if a voltage regulator off of some car or so would work. I am having little trouble finding OEM.
Car voltage regulators control the voltage by adjusting the alternator field current. Small engines do not have a field, so the answer is no. It's a totally different design.
Sorry
Bob Rip
/ PTO
Thanks Bob. I was afraid of that.
Do you not have a Robin dealer in your area? Perhaps one of the guys on this forum live close by one and might consider helping you. I would think that a Kohler regulator might work. Jack Robin might also hook you up to come one close.
J_J
<font color="red"> For safety reasons, I would have thought that the solenoid voltage would have come from the accessory terminal on the switch.</font>
You are correct, that is the way it comes from the factory. When/if I replace the ignition switch I will remove my modification.
Dale
/ PTO
Wow! Thanks for the link DHS. Looks like I can just order the part and have it shipped to the house. Thanks to JJ as well for having the idea. and to Bob for stearing me away from trouble.
You never said whether you found the problem that caused the burnout. If you put the new one in, it may burnout if you haven't isolated the problem. I would start the engine, and see if you have about 24 to 26 volts AC coming from the alternator. That regulator is also a rectifier for the AC voltage to change it to DC, and regulate the voltage. Good luck.
/ PTO
Thanks JJ. I ordered the regulator from jackssmallengines.com today and rebuilt the wiring. I will be sure and check the voltage before installing the regulator. I am in hopes that it just shorted out but your right it might pay to check it. I let you know in a few days (subject to the arrival of the regulator) how this little job comes out.
Stray,
Glad to see your V/R is on the way. J.J.'s advice to check the charging coil voltage is good advice. Take a look at the thread titled "Robin Engine Charging Capacity" The output of your charging coils @3600 rpm should be 36-60 volts AC. The voltage regulator rectifies the AC to 13 - 18 volts DC. Be careful not to short or ground the two charging coil wires with the engine running. The engine must be pulled to replace the charging coils.
Dale
/ PTO
The new regulator came in and has been installed and is in use. Everything seems to be working fine. The new one is physical smaller but with the same bolt hole centers. I also had to space it away from the frame to keep the connections from coming in contact with the frame. I don’t under stand it but where I ordered one of these regulators and one was all that I paid for and one was all the inventory sheet stated. There were 3 (three) in the box. I wander what gives? 3 for the price of one?
Stray,
My original Robin voltage regulator was the larger 30 amp model. I went through two of them in less than a year. The smaller 15 amp model is considerably less expensive and has kept working for over three years. Jacks small engine must have sent you a bonus. I used a spacer when I installed my 15 amp V/R also.
Dale
Chemical Containers Tank (A57148)
Chemical...
10222 (A56858)
10222 (A56858)
2014 Ford F-250 4x4 Ext. Cab Pickup Truck (A59230)
2014 Ford F-250...
2018 John Deere TX (A53317)
2018 John Deere TX...
UNVERFERTH 330 - 22-INCH EXTENTSION TUBE FOR BASE AND WING ASSEMBLY FOR RIPPER (A55315)
UNVERFERTH 330 -...
30in. Forks and Frame Mini Skid Steer Attachment (A59228)
30in. Forks and...
