pulled the trigger on Markham toothbar
/ pulled the trigger on Markham toothbar #1
wedge40
I called last Thursday and ordered a tooth bar for my FEL. I was told it would be two weeks before they will be able to ship. Which was fine with me cause I'm traveling for work the next two weeks so I wouldn't be able to do anything with it till then anyhow. Next is to get some wood to make a form to build my ballast box. After reading on TBN the decision to choose Markam was pretty easy.
I just looked at thread on build it yourself about someone who built his own and he spend $240 for the teeth alone. Mine is about $270 including shipping. Then again I don't have a 6' bucket either.
Wedge
/ pulled the trigger on Markham toothbar #2
ordered mine last Thursday too..it's coming to Canada so will probably take more than 2 weeks. I ordered a 6 tooth version for a JD 53" bucket.
/ pulled the trigger on Markham toothbar #3
I just spent $240 for eight teeth, but a Markham Tooth Bar would have cost me with shipping about $370.
Joe
/ pulled the trigger on Markham toothbar #4
The variety of teeth and shanks is great and they go from dirt cheap (and barely worth it!) to very expensive $100+ each. All depends on what you will use them for and what they are mounting to. So, it's tough to compare a built tooth bar to "tooth cost" as it's about impossible to know which components are being compared!
Still, the Markham bar is a good one at a fair price.
GIJOE - Colt? don't you mean Musket?
jb
/ pulled the trigger on Markham toothbar #5
I hope you gave them the exact interior dimensions as they will subtract a quarter inch to allow for clearance. If you allowed for clearance too, then it's washer spacer time for you.
I gave the correct dimensions (I hope). I thought about subtracting 1/8" and figured if it was too small I could use washers to fill in the gap.
I measured twice, so I think I'm pretty safe.
Wedge
/ pulled the trigger on Markham toothbar #8
Mine doesn't have a trigger.
Can't figure how you pull the trigger before you have it either.
Ralph
/ pulled the trigger on Markham toothbar #9
Wedge
Mine is supposed to ship this week...cost me $172 + $43 shipping to NH (that's New Hampshire not New Holland):D
Well it's been here for a couple of weeks, and I finally got around to putting it on. Haven't tried it out yet.
It fits pretty well. But my bucket has a lip around the upper edge that needed to be "fixed" before it would install proper. Got the HF grinder and after about 20 or 30 minutes of grinding it now slips on pretty easy.
Here it is. I'm thinking getting some caps to put on the end of the bolts.
Front view shows the same gap people talk about.
Here is a close up of the gap.
And again.
The gap on mine is about 5/8". I might have someone weld another edge on the fell to fill this.
I'll check it out next week.
Wedge
378909 (A61166)
378909 (A61166)
Zero Turn Mower (A59231)
Zero Turn Mower...
2021 CATERPILLAR 745 OFF ROAD DUMP TRUCK (A62129)
2021 CATERPILLAR...
(APPROX. 60) UNUSED MISC SIZE RATCHET STRAPS (A62130)
(APPROX. 60)...
2023 Chevrolet Express 2500 Cargo Van (A61568)
2023 Chevrolet...
UNUSED JCT 72" HYD BRUSH CUTTER (A62131)
UNUSED JCT 72" HYD...
