Pulling out remainder of broken-off 6x6 fence post
   / Pulling out remainder of broken-off 6x6 fence post #1
joshuabardwell
Elite Member
Knoxville, TN
Bobcat CT225
My fence has several places where there is a 6x6 post with a long (drive-through, opens-in-the-middle) gate hanging on one side and a short (walk-through) gate hanging on the other side. Two of them have recently broken off at ground level--probably rotted away, I would guess. I would love to be able to get the old post out and re-use the existing hole for a replacement. Does anybody have any tips for how to do this?
One thought that I had was to treat it like a stump, drill some holes in it, fill it with diesel, and start it burning. This would leave a neat 6x6 hole to receive the next post, but I'm not sure whether it would reliably burn out completely. Alternatively, I thought maybe I could affix some kind of an anchor and pull the post out with my tractor. But I'm not sure what I could sink into the post, especially into the end grain, that would hold strong enough to take the post out.
Any other suggestions?
   / Pulling out remainder of broken-off 6x6 fence post #2
Dig down around it for a foot and wrap a chain around it and try to use your FEL or 3PT hitch to lift it straight up.
   / Pulling out remainder of broken-off 6x6 fence post #3
I like the driving in some kind of anchor and pulling it out.
   / Pulling out remainder of broken-off 6x6 fence post #4
If concreted in,dig down around it,use long metal bar to break concrete. It breaks a lot easier if it has room to break away from post.
   / Pulling out remainder of broken-off 6x6 fence post #5
Seems to me that a long lag bolt (3/8 or 1/2) tapped into the top should work if you can get a vertical pull with a tractor. I've done something similar just using the hydraulics on a plow truck. You might find that it is rotted though and you won't get a bite. So then I guess the burn method. I wonder if anybody has ever tried using hot charcoal on something like that? Slow burn but sustaining.
   / Pulling out remainder of broken-off 6x6 fence post #6
Try lifting it with your tooth bar
   / Pulling out remainder of broken-off 6x6 fence post #7
using a large Eye Bolt in the top may work if only bare dirt. Use the FEL to push it back & forth a bit to loosen the grip of the dirt.
you can also use a big Spud Bar down along side to pry it back & forth a few times then come in at an angle to the post drive the spud bar in some or drill a hole using a spade bit & battery drill so there is something to bite into on the post. then use a 4x4 as a pivot point to pry it up & out if you cant get tractor close.
Next option is to use Dynamite a "HOLE" bunch :D my preferred method j/k lol. but not sure how cold you all are getting now you can also shovel out around it some to form a bowl use a sledge hammer to beat it back & forth some then fill hole up with water. let it freeze and drain along the post side come back in a couple hrs and beat it back & forth in the muddy hole and then pry out.
additional option is to NAIL or SCREW a 2x4 onto the top one or 2 sides and chain under/around it still requires some digging. then FEL or Spud Bar to pop it up also can use a FARM JACK or old style Bumper Jack to JACK it out of the ground.
Mark
   / Pulling out remainder of broken-off 6x6 fence post #8
Whatever method you use, by the time you have the post out, the hole isn't going to be a neat 6x6 hole anymore. You're gonna end up cleaning the hole. I'd use the chain loop method as described above.
   / Pulling out remainder of broken-off 6x6 fence post #9
I wonder if a fire would get enough oxygen to burn in a hole that small and that deep.
I agree that digging and wrapping a chain could work and an anchor might work as well, maybe a large lag bolt screwed into the top to pull from.
Something to think about is why it broke to start with. If you have a long gate on one side and a short gate on the other it sounds like there is no brace. If the gates rest on something like a block or the ground then that probably isn't a problem, but if the weight of the gate is hanging on the post with out a brace then it could be the reason the post broke.
2023 54' Hooklift Dumpster 15 Cubic Yard (A55788)
2023 54' Hooklift...
2018 FORD TRANSIT T150 CARGO VAN (A54313)
2018 FORD TRANSIT...
2014 DODGE CHARGER (A51406)
2014 DODGE CHARGER...
JOHN DEERE 8R 280 (A53084)
JOHN DEERE 8R 280...
2018 UTILITY VS2RA 53FT REEFER TRAILER (A53426)
2018 UTILITY VS2RA...
2018 FORD F550 SERVICE TRUCK (A51406)
2018 FORD F550...
