Pulling out remainder of broken-off 6x6 fence post
   / Pulling out remainder of broken-off 6x6 fence post #11
In most cases someone drove into it with a tractor.
Now who in the world would do a thing like that? :)
Back in the summer a guy was pulling a four wheel hay wagon out of one of my gates onto the road. A 20' wide opening, two 10' gates actually. Anyway he hit the end of one of the open gates with the front of the wagon. It put a slight bend in the heavy duty gate (less than a year old) and pulled the bed half way off the wagon frame.
I was pretty mad but luckily it was his wagon and it didn't break the 10" post.
   / Pulling out remainder of broken-off 6x6 fence post #12
I hear ya. The only dent in my car hauler trailer fender came from me hitting a tree while trying to avoid the gate post! :laughing:
   / Pulling out remainder of broken-off 6x6 fence post #13
Yep never sure WHO hits stuff with my tractor or the car trailer :eek: ok maybe I could have a clue (wisper wisper wisper) sorry I've been advised to take the 5th :D
M
   / Pulling out remainder of broken-off 6x6 fence post #14
Pulling straight up has worked for me a few times. This was with a 4x4 post. I got the biggest lag bolt I could find at the hardware store, then drilled down through the top with the appropriate sized bit, and finally, screwed the lag bolt in tight. I made a quick frame with a couple of 4x4 posts, and then one across the top. I hung my come-along from that and pulled straight up. Came out with a perfect hole. I dropped the new post in, and I was done.
The times this has not worked, I dug down about 6 inches on each side of the post and gave it a few whacks on the side with an 8lb sledge. Hitting it with your backhoe bucket or FEL might do the trick as well. Once it was loosed up a bit, it came right up.
If you want to use your tractor to lift, then I would lift from the 3pt hitch. Easier to lift straight up, and you can lift more.
   / Pulling out remainder of broken-off 6x6 fence post #15
The burn with diesel idea ---- supercharge the airflow with a leaf blower... should burn out in no time.
Something to think about is why it broke to start with. If you have a long gate on one side and a short gate on the other it sounds like there is no brace.
Exactly. Whomever designed the fence put a bunch of these places in where there is a drive-through gate on one side and a walk-through gate on the other. It's just a 6x6 post in the ground with two gates hanging off of it--one of them about 8' long. The two that broke are on a hillside that sees a LOT of water running down it, so my guess is that's why they broke. I'm not sure how to fix it, though, short of taking out the drive-through gates and putting in fence rails instead. How can you brace something like that?
   / Pulling out remainder of broken-off 6x6 fence post #17
Dig down around it for a foot and wrap a chain around it and try to use your FEL or 3PT hitch to lift it straight up.
I work construction. pulling out old decks and such. Chain and FEL is by far best method. If it won"t pull right up, lift and drive forward and back a bit at the same time.
   / Pulling out remainder of broken-off 6x6 fence post #18
Redesign it with a single opening so you can brace the posts. A 8-12ft single gate is no problem to walk through by opening it just a little bit. If you really want a small gate, make a double gate with an 8ft and a 3ft, for example.
Bruce
   / Pulling out remainder of broken-off 6x6 fence post #19
If you take out the longer gate and leave a short walk through gate (4' I'm assuming) you probably wouldn't have to brace it at all.
You could leave both and put a wheel on the end of the longer gate or leave a block of wood, a rock, brick or something like that at the end to keep the weight off of the post. Then I think you would be fine without a brace.
   / Pulling out remainder of broken-off 6x6 fence post #20
Over the years when I was on the Line crew we pulled a ton of power poles! Easy when you have many feet sticking up to wrap a boom tip winch cable around, eh? :D. Seriously, for ordinary 4x4s or 6x6s, sometimes a chain and JackAll work the best, just have to dig down a ways to get the chain wrapped around the stump. I've had instances where the stump was rotted into a pointed shape so no way would the chain grip it, a lag screw or two would hold it down enough to tighten and then it pulled out with the jack. Sometime a jack works better than a front end loader as you can see what's happening. Use the loader to carry the jack, chain shovel and stumps.
2015 KENWORTH T680 SLEEPER (A54607)
2015 KENWORTH T680...
UNUSED SWICT 84" QUICK ATTACH BUCKET (A54757)
UNUSED SWICT 84"...
2021 FREIGHTLINER CASCADIA SLEEPER TRUCK (A54313)
2021 FREIGHTLINER...
2001 International 4700 Dump Truck, VIN # 1HTSCAAM51H379512 (A54865)
2001 International...
1987 EZGO Golf Electric Cart (A53424)
1987 EZGO Golf...
2025 JMR 72in Dual Cylinder Grapple Skid Steer Attachment (A55787)
2025 JMR 72in Dual...
