Pulling Tree Stumps Safely
   / Pulling Tree Stumps Safely #71
AndyMA said:
Of course if we weren't trying to do something that a backhoe is designed to do with the wrong tool we wouldn't be having this discussion.
Andy
Yeah, I'll have to agree with that. I don't really see the value in determining whether chain/wire rope would kill you or just seriously injure you. It is comforting to know that it is unlikely to cut you clean in two.
You guys can count me out in the experiment:)
   / Pulling Tree Stumps Safely #72
When my grandfather gave up using his team of mules and went motorized, the first thing he did to the new tractor was to build a stump puller frame. He used two pieces of channel iron, running the length of the tractor, U-shaped at the axle and bolted on it, running from the axle all the way past the radiator and front cowl. I dont remember how it was bolted to the front and sides, likely to somthing solid. Running between those two side , under the transmission, one side was a reciever type(slightly larger) - the other side was your male end that slid in to the channel. Much like your trailer hitches these days. He ran two of these between the side rails , spaced about two inches or so apart. (wide enough for the heavy log chain) - dead center of these two cross members, he drilled a hole for a large case hardened ships bolt, which you lifted up the chain, pushed in the bolt from the front side, and the chain was just kind of looped over it. Hope that makes sense..
That chain was then run thru a tire at the rear, (sometimes two stacked on top of each other) then the other chain went around the stump. The tires acted as a stretch and slack device and kept the jerking to a minimum.
He always said that the frame was for pullin stuff, and I remember watchin as the tractor kinda hunched down or dug in a bit and then what ever he was hooked to, came loose as the tractor started moving. He always pulled in low gears. I helped him and his neighbor pull out a combine that was stuck in the mud and I remember how small the tractor looked in comparison to the big machine. Despite the size and weight difference it still pulled it out. That frame was always used, the rear hitch was for hooking implements to and nothing else.
   / Pulling Tree Stumps Safely #73
I have never considered pulling a stump with a tractor. After reading all this I will still not consider pulling a stump with a tractor.
   / Pulling Tree Stumps Safely #74
It takes a tremendous amount of force to pull a stump out of the ground. Even a small one. Therefore a tractor, even a big one, is not the right tool to pull it out. I wouldn't even bet on a bulldozer. The first one I pulled out with a big back hoe took me thirty five minutes of digging to break the roots loose before the hoe could muster up enough juice to pull it out of the ground. That convinced me that I could forget about getting enough traction out of anything I could lay my hands on to pull it out of the ground.
   / Pulling Tree Stumps Safely #75
Whenever you want to do some serious pulling, you should ONLY use the draw bar as it is located below the level of the rear axle and thus nis less incluned to tip you over backwards. Also, always pull in a straight line. If the tractor is at an angle to the chain, that too could cause an upset. Finally, I agree with the other threads, you're not likely to be able to pull the stumps out. I cut them as low as possible and then I use a mini Husky stump grinder to chew them flush. Haven't had the patience to wait for those chemicals to decompose the stump.
   / Pulling Tree Stumps Safely #76
DenisM said:
Want to pull some tree stumps, What is the best place to attach the chains to the tractor? Have a draw bar and was thinking of using chain hooks at the ends of the bar? Is it better to attach the chains to the loader bucket? Is it better to use straps instead of chains?
Stumps aren't that big; but still don't want to take a chance on damaging anything on the tractor.
Thanks for any ideas or thoughts.
I haven't read through all of the posts yet but getting stumps out is a chore and dangerous with a tractor. I dug most of mine out with a back hoe.
For the really big ones, I drilled multiple hole with and electric drill vertically down as far as I could reach. I would fill those holes with diesel every few days until I was satisfied that the stump was fairly saturated with fuel. Then light it like a candle. It will smoke for days but when it is done, the stump will burn several feet down into the ground. You will need a little fill dirt to cover the hole.
   / Pulling Tree Stumps Safely #78
Why pull them. cut them off close to the ground, and bore some holes and add some diesel fuel, let it soak in, and then build up a pile of charcoal briquette's and light it off and it will burn. You can also add a small blower to help the fire.
2024 CATERPILLAR 255 SKID STEER (A52707)
2024 CATERPILLAR...
2022 Schulte 2500 Giant Rock Picker (A56436)
2022 Schulte 2500...
1999 John Deere 7810 (A60462)
1999 John Deere...
Feterl 60' PTO Unoading Auger (A59814)
Feterl 60' PTO...
CAT D5G LGP DOZER (A58214)
CAT D5G LGP DOZER...
2021 CATERPILLAR D5 LGP HIGH TRACK CRAWLER DOZER (A52709)
2021 CATERPILLAR...
