Pump and reservoir size
   / Pump and reservoir size #11
Hey, on my MT 180D I run a splinter and have no cooler provisions.
Last fall we split some 5-7 cords without a single hitch.
My splinter is a 5 inch cylinder on a H beam that is 3 point mounted.
It split everything that was presented to it and never burped.
We even cut some maple to length but that kinda stressed the H beam and made a horrible noise. LOL!
Hint--- don't over think it!
   / Pump and reservoir size #13
You sure thats not the rod dimensions? IF the bore is indeed only 1.5, you need a different cylinder as that would struggle to split twigs
   / Pump and reservoir size #14
The ability to run without a cooler really comes down to how efficient the system is, how much mass is there (oil and steel) and how hard are you going to push it. The reality is systems run above 180°F without immediate consequence all the time, but it does age the oil and rubber components faster. The rule is every 10°F cuts the oil life in half. If you only use the splitter a couple times a year your will probably have water issues before it gets oxidized. ISZ
2007 Chevrolet Silverado Ext. Cab Pickup Truck (A44572)
2007 Chevrolet...
4Yd Dumpster (A44571)
2015 Crane Carrier Low Entry New Way 31Yd Side Loader Garbage Truck (A44571)
2015 Crane Carrier...
Fleco 18" 6T Excavator Bucket (A42203)
Fleco 18" 6T...
Sandpiper 20' Sailboat (A44502)
Sandpiper 20'...
Fleco 36" 8T Excavator Bucket (A42203)
Fleco 36" 8T...
