Pump or no pump for my BH80-X
   / Pump or no pump for my BH80-X #1
mpwr
Sudbury, MA
I'm going to get a BH80-X for the B3030 I'm buying. I'm getting different advice from the dealers about getting the Woods pump.
Neil Messick suggests I don't get the pump. It will save money. The tractor puts out 9 gpm and the Woods pump only does 6.
My local dealer suggests the pump. He says 95% of his customers get it. (I forgot to ask him whether that was customers in general or specifically B3030 customers). He says it will save heating of the tractors hydraulic oil and will increase the life of the tractor.
What do you think?
   / Pump or no pump for my BH80-X #2
Shame on you Neil Messick.
The implement flow on the B3030 is only 5.2 gpm according to the Kubota literature while the power steering is 3.9 gpm, giving 9.1 total. That means only 5.2 gpm is available for the backhoe.
It is interesting to note that the B2710/B2910/B7800 all have 6.4 gpm available for the implement flow while the B2630 has only 5.6 gpm available for implements.
Well Neil, what say you about this?
That's interesting. I didn't realize part of the tractor's pumping capacity would be used up by the power steering. But obviously, on reflection, 9 gpm is the total capacity of the pump, and anything that uses the hydraulics, including the steering, would use some of the capacity.
I wonder, though, if the tractor is stopped, and you're not steering, if it would still take up 3.9 gpm?
   / Pump or no pump for my BH80-X #4
I believe there are two separate pumps.
   / Pump or no pump for my BH80-X #5
Actually, for the B and L series tractors Kubota uses two pumps, one for the implement hydraulics and one for the power steering hydraulics. Neither's flow can be mixed or combined with the other. For marketing purposes they sometimes add the two gpm's together to get a higher number since the competition is doing the same.
Wow. That sounds like that old "Does your dog bite? No. (Chomp). That's not my dog" joke. Including in the specs the output of a pump that doesn't drive any implements!
   / Pump or no pump for my BH80-X #7
I have a b7800 with woods 7500 backhoe driven from the tractor hydraulics. I am not happy with the way it works.
I can not perform simultaneous operations with the backhoe controls unless I carefully very very carefully feather the controls. Now I don't know if this is caused by pump capacity, power beyond or if it is just the way it works.
I was told the Kubota hoes all come with a seperate pump.
I think I only saved a coulpe of hundred dollars.
   / Pump or no pump for my BH80-X #8
I suggest you demo the backhoe with and without the pump.
   / Pump or no pump for my BH80-X #9
It could be the cumulation of several things including flow capacity and backhoe valve block design. It is definately not power beyond because that is simply a method of connection, unless it is plumbed incorrectly.
The advantage of having a seperate pump for the backhoe is that it will be sized to optimally operate the backhoe. You will not need any additional tractor plumbing. It may cost a few dollars more but, in my opinion, is well worth it.
   / Pump or no pump for my BH80-X #10
Check the HP requirments for the BH-80x, no offense intended here, but the 3030, may be on the small side for the BH-80x.
Regards,
Bryan
2019 POLARIS RANGER XP PROSTAR 900 HD DOHC UTV (A51406)
2019 POLARIS...
2013 INTERNATIONAL MA065 CAB AND CHASSIS (A52472)
2013 INTERNATIONAL...
2021 Redirective Crash Cushion Guardrail (A51692)
2021 Redirective...
Wood Fence Posts (A50121)
Wood Fence Posts...
New Kivel Single Skidloader Spear (A50774)
New Kivel Single...
