Puzzling electric fence problem
/ Puzzling electric fence problem #1
n8wrl
Rural SC
Kubota L5030 HST
I have several segments of fence charged with 6v solar chargers. I have a very puzzling problem with one segment.
We have a combination of PVC-encased fencing and electric on wooden posts. On this one segment I am getting a tickle from the metal tensioners at the ends of the PVC fencing. I have gone over the electric wire carefully examining each insulator and I can't see where the connection is.
For grins I got out my trusty ohmmeter. On the top PVC line I measure about 10Meg-ohms between the electric fence wire and the wire encased in the PVC. I measuere infinite resistence (open, or no connection) on the other lines and on the other fence segments, as I would expect. Apparently 10Meg is enough to get a tickle when the grass is wet but not with dry grass and shoes.
I have trimmed out the bulk of the fencing to just one line and I still get the tickle. It seems to travel down the wooden post to the other PVC lines as well. I have swapped out the charger. When the electric is disconnected, no shocks at all.
Some of the insulators are pretty old - is it possible current is bridging the gap to the nail?
What am I missing?
/ Puzzling electric fence problem #2
I'd check the old insulators, looking for a crack that lets current bleed through especially when wet.
Chuck
/ Puzzling electric fence problem #3
I would agree, check the old insulators for cracks, or even heavy rust streaks from the nails. I doesn't really take much, especially with a little moisture.
/ Puzzling electric fence problem #4
I had a short because of bird poo on an insulator once. I know it's a long shot but figured it's worth mentioning.
/ Puzzling electric fence problem #5
You measured resistance between the electric fence wire (with charger off/disconnected) and each of the PVC lines on this section of fence? The PVC lines have a metal conductor inside and are coated with PVC? How are the PVC conductors terminated at each end, are they grounded or floating?
You said the tickle seems to travel down the wooden post to the other PVC lines as well, I'm not sure what you mean here, do you feel/measure voltage on the other PVC lines?
I have a solar fence charger, it's output is pulsed about once per second, is your system like that?
You measured resistance between the electric fence wire (with charger off/disconnected) and each of the PVC lines on this section of fence? ?
Yes
They are gounded in that they wrap around the metal tensioner that is nailed to the post.
I'm 'testing' by touching the tensioners - there are several on each post. I'm measuring the resistence between the top-line/tensioner and the electric fence wire with the charger disconnected. The top tensioner reads several m-ohms, all the rest read an open circuit.
But I suspect the charge travels down the wooden post because I feel a tickel on ALL the tensioners on the post.
That is correct. While the charger is pulsing, I feel the tickle at the same frequency. When the charger is off, no tickle.
/ Puzzling electric fence problem #7
Most solar units are pulse, high impedance type vs constant current types.
any restive connection will let high votlage travel across it.. ie wet surfaces.
I've seen bad grounds at the charger make some funny 'issues' as well.
soundguy
What am I missing?
/ Puzzling electric fence problem #8
I believe the problem may be a cracked insulator. if your using an ohmeter, you cannot measure the ablity to arc. The problem should diminish with drier weather like a cracked distributor. Try lifting the wire while someone measures the voltage. A sharp rise in volts means you found it.
/ Puzzling electric fence problem #9
check it at night, you can sometimes see a little arch at night that is really hard to find otherwise.
heehaw
/ Puzzling electric fence problem #10
Simply slowly drive your fenceline with your radio tuned to an AM station. When you get a lot of static in your radio pulsating about every second, you are near the bad spot in the fence.
/ Puzzling electric fence problem #12
We use the same method on tracking static on our electric power lines. Although, the low AM stations will be mis-leading and noise can travel for miles. Normally you can narrow it down pretty easily. I've also found that even on a good hot-wire fence, AM radio will pick up each pulse. We have a special sniffer for this around 330mhz that will narrow it down within a few feet.
I'd drive it slow at night and have someone shake the line real good to possibly see the arc. You can do that with AM radio station fairly low band too. The noise will get louder on the shake and the closer you get to the problem.
/ Puzzling electric fence problem #13
I had a similar problem after a lightening strike hit my fence. It destroyed my charger but the new one showed grounded all the time. After trying everything else, I replaced the insulators on the section of fence hit by lightening back to the charger. It started working after that. Several of the insulators had hairline cracks that were not visible until I had them in hand. Good luck.
DRILL CABINET SKID (A63569)
DRILL CABINET SKID...
Mini Skid 6 Way Blade (A56438)
Mini Skid 6 Way...
1998 FORD F-800 4X2 S/A FLATBED/ TANKER (A59910)
1998 FORD F-800...
DRILL CABINET SKID (A60736)
2013 INTERNATIONAL DURASTAR 4300 M7 SWEEPER TRUCK (A63276)
2013 INTERNATIONAL...
2006 Ford F-150 Ext Cab Pickup Truck (A61573)
2006 Ford F-150...
