Quad tires for PT Tires
   / Quad tires for PT Tires #21
I purchased from GCT Wholesale [gctwholesale@cox.net] Contact them for details or Google search.
I bought these
2 23x10 50 12 4 Ply Kenda K502 Terra Trac ATV Turf Mower Tires | eBay
They have an E-Bay store .... Deestone D265 Turf, Deestone Lug items in GCT Wholesale store on eBay! with lots of tire options.
A quick search shows size 24-12-12 is available but $304.91 per tire is YIKES!
1 24x12 00 12 24 12 12 Kenda K502 Terra Trac Lawn Mower Golf Cart Tire 4ply | eBay)
or 2 24x12 00 12 24 12 00 12 Kenda K502 Terra Trac Lawn Mower Golf Cart Tire 4ply | eBay
for two tires at $419.87
   / Quad tires for PT Tires #22
I bought these
That $304 tire would be the one to have....but dang, that is wayyyy out of line.
   / Quad tires for PT Tires #23
J Cummins:
Just stumbled across this. Showed up in my "You might also like section" when I was on E-bay.
2 26x12 00 12 26 12 00 12 Kenda K502 Terra Trac Lawn Mower Golf Cart Tire 4ply | eBay
If you can handle a 26-12-12 4-ply version of the Tera-Trac tire with a B-rating and load capability at 1780 lbs, this might be for you. A pair is $230.
The added diameter will increase ground clearance but reduce torque.
or single tires here for $142 with free shipping.
Kenda K502 Terra Trac 26 12 00 12 Lawn Garden Turf Tire | eBay
Rick
PT-422
   / Quad tires for PT Tires #24
J Cummins:
Rick
PT-422
is the 26 of this size definition the width? 2nd number 12 is aspect ration, 3rd number rim size. If so these might work. Given that it wouldn't add anything to ground clearance. Am I interrupting correct?
   / Quad tires for PT Tires #25
26 IS DIAMETER
12 WIDTH OF TIRE
12 IN RIM
   / Quad tires for PT Tires #26
This is my cache of tires.
   / Quad tires for PT Tires #28
Hmmm, price may be high, but what about tires made for compact tractors with FELs?
prs
   / Quad tires for PT Tires #29
Might be worth considering foaming the tires if you are that hard on them and have issues with flats. I run the same size on my little skidder.
Foam is so appealing until you get into a slope situation and the hardness of the tire is no longer beneficial., A bummer for sure. Would foam if it wasn't for the severe slopes I have.
2018 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2018 DRAGON 150...
2017 Ford Explorer AWD SUV (A54815)
2017 Ford Explorer...
2012 Trail-Eze TE801 48ft 50 Ton Slide-Axle T/A Tilt Trailer (A51691)
2012 Trail-Eze...
2001 Dodge Ram 1500 Pickup Truck (A55852)
2001 Dodge Ram...
2010 Hyundai Elantra Touring Sedan (A54815)
2010 Hyundai...
2018 K-TEC 1228 PULL TYPE DIRT PAN (A52707)
2018 K-TEC 1228...
