Question about using a disc harrow
/ Question about using a disc harrow #1
Arkinsaw Dave
Nw Arkansas
Mahindra 6520 4wd
When using a 3 point disc harrow, should you leave the pins out of your stabilizer bars or leave them in?. thank you.
/ Question about using a disc harrow #2
I like the disc to be able to float with the ground conditions (cuts better) and that way is also easier on the tractor 3 point and stab bars. Ken Sweet
/ Question about using a disc harrow #3
Leave the pins in so that when you make a turn, with the disc raised, swinging will be limited to keep your lower links from bending/breaking. Avoid turns, other than very gradual ones, with the disc down. I broke a few lower link arms on my Ford 8n with a 6.5 ft 3-point disc, before I sprung for a stabilizer bar kit, which eliminated the problem. If you have a larger area to work, a pull-type disc is more effective than a 3-point of equal weight/disc due to better soil contact of all sections and this type is also made to allow turns when engaged.
BUYERS PREMIUM & PAYMENT TERMS (A59912)
BUYERS PREMIUM &...
KUBOTA M7040 TRACTOR (A63291)
KUBOTA M7040...
Misc. Tires (A61573)
UNUSED ATSPOWER GASLESS WELDING MACHINE (A64281)
UNUSED ATSPOWER...
Fellabuncher Dangle head, PARTS ONLY (A62679)
Fellabuncher...
Crate of Misc. Parts (A64119)
Crate of Misc...
