Question about using a disc harrow
/ Question about using a disc harrow #1
Arkinsaw Dave
Nw Arkansas
Mahindra 6520 4wd
When using a 3 point disc harrow, should you leave the pins out of your stabilizer bars or leave them in?. thank you.
/ Question about using a disc harrow #2
I like the disc to be able to float with the ground conditions (cuts better) and that way is also easier on the tractor 3 point and stab bars. Ken Sweet
/ Question about using a disc harrow #3
Leave the pins in so that when you make a turn, with the disc raised, swinging will be limited to keep your lower links from bending/breaking. Avoid turns, other than very gradual ones, with the disc down. I broke a few lower link arms on my Ford 8n with a 6.5 ft 3-point disc, before I sprung for a stabilizer bar kit, which eliminated the problem. If you have a larger area to work, a pull-type disc is more effective than a 3-point of equal weight/disc due to better soil contact of all sections and this type is also made to allow turns when engaged.
2019 Freightliner 122SD (A62679)
2019 Freightliner...
UNUSED WOLVERINE QUICK COUPLER 8 (A64281)
UNUSED WOLVERINE...
2005 PETERBILT 379 TRI AXLE  DUMP TRUCK (A59575)
2005 PETERBILT 379...
2019 JOHN DEERE 333G SKID STEER (A64279)
2019 JOHN DEERE...
Redball 6 Row Hooded Sprayer (A64119)
Redball 6 Row...
2017 KALMAR OTTAWA T2 4X2 SPOTTER TRUCK (A60430)
2017 KALMAR OTTAWA...
