Question Concerning Loader Methods
   / Question Concerning Loader Methods #11
I agree, if you're going to be doing this a lot you may need a grapple!!
Especially, if you're going to be lifting big limbs!;)
   / Question Concerning Loader Methods #13
Hey Mud:
I did this for 15 years with homemade bolt on forks (two pieces of channel iron and holes through the loader bucket). It worked fine, but with my tractor upgrade I have a toothbar and a bolt on grapple for the bucket. This works great, but I wouldn't have done it if I didn't have a whole lot more logs and brush to move than before.
Steve
Thanks Steve! I'm also looking into a grapple attachment.
   / Question Concerning Loader Methods #15
I am a little shocked you posted the pic "wider than the bucket." I hope those tires are loaded, but even if they are there is not enough ballast there. There is daylight under the left rear tire. Oh... and using ROPS with no seat belt on...:( That pic has the makings of a disaster. Cool attachments though. I have seen them on your website in the past.
   / Question Concerning Loader Methods #16
Thank you for bringing that BAD photo to my attention - I've deleted and reposted without the "wider than bucket" photo.
If you plan to move and clear logs, this is a unit built for just that. It attaches right to the end of the loader arms or works with your skid-steer adapter. It's just like putting fingers on the end of your loader arms. It eliminates the need for chains and hooks. It is much faster and safer way to transport logs, brush, fencing etc... and it grabs uneven loads securely. The unit on the end of the arms DOES NOT require extra hydraulics or ports on your tractor (approx. $750 to 1000). The skid-steer model will need to plug into a set of rear remotes (approx. $2100).
It is very important that you read an operators manual for your loader - contact the company you purchased it from. If you are new at operating your loader, you can get some great tips and a lot of do's and don'ts that can save you costly repairs. You can access John Deere loader/operator manuals online.
   / Question Concerning Loader Methods #17
I've moved a lot of trees, stumps, limbs, etc that were wider than the bucket without a grapple, tooth bar, forks, hooks, etc. It takes a lot of finesse and a lot of back and forth (when you drop them). But, it can be done, believe me. And if you do it enough, you get good at it.
But don't get me wrong. Its kind of like driving a nail with a screwdriver. The right tool for the right job is best and there are many times I wish I could afford a grapple. But when all you have is the screwdriver............
   / Question Concerning Loader Methods #18
Was this a question about how to use a fel in general, or a question only about using the fel to pick up logs?
Are you looking for info on how to work dirt with your fel too? I'm on that same journey. And it does take practice but not a whole bunch to get the basics.
What I did was gave myself a little project of moving a pile of dirt from one spot to another. (It was actually wood chips, so real light and easy to work.)
There is a small guide on the bucket that is supposed to inform you when your bucket base is parallel to the ground. It's been hard for me to tell when that gadget is truely parallel. Anyone know how to get good at that? My bucket tends to be pointed down or up which means that it is either shoving into ground or sliding up.
   / Question Concerning Loader Methods #19
Mud,
We recently purchased our first new tractor with an FEL. We decided to purchase a 66" grapple based largely on information I found on this site. I cannot believe how many uses there are for this implement. It is worth it's weight in gold in my opinion. The cost was around $1,450 installed, not including the third function valve. It is one implement that is definitely worth saving for and investing in. From a safety standpoint, it is much safer to move logs and such with also because you eliminate the opportunity for it to roll off. There are many manufacturers and there is a lot of info here, just do a search.
Here are a couple of pics for reference.
   / Question Concerning Loader Methods #20
Quote from the OP's first post in this thread:
but I want to know the best way to pick up downed trees and logs longer than the bucket itself.
Moving the wood chips is great practice.
As far as getting the bucket level, I know on mine, and most others I have looked at, the top edge of the bucket is on the same plane as the bottom edge, so if the top is level-so is the bottom. I don't even use my level indicator anymore. I am not clear what kind of level indicator you have, but mine was a rod that slid through a tube so I cut the rod even with the tube when the bucket is parallel to the ground.
UNUSED Safety Traffic Cones (A50860)
UNUSED Safety...
John Deere 6430 Side Arm Tractor (A48837)
John Deere 6430...
1994 PETERBILT 379 SLEEPER (A50046)
1994 PETERBILT 379...
FRUITLAND VACUUM PUMP (A50854)
FRUITLAND VACUUM...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A50397)
2023 New Holland...
Ryobi Sliding Compound Miter Saw (A48837)
Ryobi Sliding...
