Question on Diesel prices?
   / Question on Diesel prices? #11
Here we go again. /forums/images/graemlins/grin.gif
   / Question on Diesel prices? #12
No. 1 Diesel Fuel:
No. 1 diesel fuel (also known as 1-d) is a <font color="red">kerosene-based diesel fuel </font> most commonly used for low temperature operations. No.1 fuel has less wax content than No.2, thus providing lower cloud points. However, its lower specific gravity means less energy content compared to No.2. Available in Low Sulfur and Low Sulfur Dyed.
MSDS: No. 1 Diesel.pdf
Kerosene:
Kerosene is the lightest, most volatile of the distillate fuel grades. Also known as 1-k, kerosene meets the ASTM requirement for sulfur content of not more than 0.04% wt. % sulfur. Kerosene meets all ASTM D-3699 specifications. Available in dyed form for untaxed use at some locations.
MSDS: Kerosene.pdf
Now if you would like to debate this the way some people want to debate synthetic oils, then we best start by breaking it down by refinery and brand. If you want to start splitting hairs on this matter, you might have the lab do a chemical analysis on the fuels in this particular station if you can establish its whereabouts. Some people must pour fuel on the fire if for no other reason but to cause dissension in the forums....This seems like just one of those instances, especially with the prefaced remark of </font><font color="blue" class="small">( Not to start a war but,)</font>. I thought that behavior was limited to LBr....., but I guess that this will put you into his league .... /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
As for a direct answer to your......</font><font color="blue" class="small">( Not to start a war but, how is Kerosine and #1 diesel the same ????)</font>
and, to keep the record straight, I never said anything about <font color="blue">Kerosine</font>, however, my comment was about <font color="blue">Kerosene</font>. /forums/images/graemlins/blush.gif /forums/images/graemlins/crazy.gif /forums/images/graemlins/blush.gif /forums/images/graemlins/crazy.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
   / Question on Diesel prices? #13
Your original reply stated "# 1 diesel is kerosene" That is not quite true as you stated above, </font><font color="blue" class="small">( kerosene-based diesel fuel )</font> it is as stated at BP and Chevron, </font><font color="blue" class="small">( Kerosene:
Kerosene is the lightest, most volatile of the distillate fuel grades. Also known as 1-k, kerosene meets the ASTM requirement for sulfur content of not more than 0.04% wt. % sulfur. Kerosene meets all ASTM D-3699 specifications. Available in dyed form for untaxed use at some locations )</font>
I feel readers of the forum simply need correct information which is why I posted links to fuel sites rather than publish my opinion. Many diesels can run on #1 but kerosene is not generally recommended. By the way kerosine has two different spellings.
   / Question on Diesel prices? #14
Guys why don't we all agree to disagree on this one and just go out and take a relaxing ride on the tractor?
   / Question on Diesel prices? #15
Junkman,
I know things are different in the East. In the midwest and west #1 diesel is NOT kerosene. #1 is a mix of diesel and kerosene to lower the gel temp. Usually it's a 50/50 mix. #2 is regular diesel. If you pull into say the Flying J you have three choices for "diesel". #1 diesel is going to be winter blend 50/50 kerosene and #2 diesel usually good to a temp. of -10 to -20. #2 diesel is going to be straight diesel usually good to a temp. right at freezing or maybe a little below. Then at another pump you can buy straight kerosene.
I admit I don't know about the East and #1 very well may be considered straight kerosene. But just like our home heating oil is different here it may very well be that kerosene and #1 are one and the same where you are. Here in the midwest all the way to the Pacific it isn't the same.
penokee,
The reason that #1 is so much higher is because of the kerosene in it. Kerosene is considerably more than regular diesel. The on road fuel you are seeing is the same as the #2 off road diesel. Comparing apples to apples you are getting 41 cents off the price of off road fuel. I know it gets cold where you are. I would buy the regular off road #2 diesel and treat it with an anti-gel formula like powerservice. You will get much better performance and lubrication from #2 than #1 and save yourself a bunch of money on the price of the fuel.
   / Question on Diesel prices? #16
cowboydoc,
I use #1 heating oil to heat my shop and run my Kubotas. I've been doing this for 20 years now with no issues or problems. Just throw in a quart of anti-gel to treat the fuel in the winter months and your good to go /forums/images/graemlins/smile.gif.
Bill
I appreciate the replies.
DmansPadge - The Hot Wine is for Winter only - acquired the Hot Wine habit after consuming too much Hot Saki in Japan back in 55.
Junkman - Both are dyed red. Use #1 off-road in my camp space heater.
Cowboydoc - Have been using #1 on-road in my Kubota, think I will switch to #2 off-road + Power service additive.
Thanks all - penokee /forums/images/graemlins/smile.gif
   / Question on Diesel prices? #19
Just don't mix up the dyed #1 with the hot wine...... /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A52377)
2021 Allmand Bros...
3-Point Hitch Root Grubber - Heavy-Duty Tree and Stump Puller for Tractors (A55301)
3-Point Hitch Root...
2021 JOHN DEERE 648LB SKIDDER (A51406)
2021 JOHN DEERE...
2013 Club Car Carryall 252 Electric Utility Cart (A51694)
2013 Club Car...
2011 DOOSAN G40 GENERATOR (A53843)
2011 DOOSAN G40...
