Snow Attachments Question on possible installation of a snow plow.
   / Question on possible installation of a snow plow. #11
my snowplow (truck mount) was 250 bux. i cannibalized it to mount on my 4x4 forklift. unstoppable.
   / Question on possible installation of a snow plow. #12
Does your truck have a plow on it now? If not a used setup will cost some money ($2000). A cheap, non roadworthy plow truck with plow will run the same price.
But to limit the amount of junk in your yard, a used compact tractor will do all you need. It would probably be your best and most economical solution.
   / Question on possible installation of a snow plow. #13
I would not drive a 2wd truck in snow never mind try to plow with one. As noted plows are not low cost and about 40% of the cost is on the truck side, frame plus electronics. As suggested look for an older used 4wd truck with a plow already attached or look for someone else to plow. The latter is the better option as you will need a 3/4 ton 4wd truck and sturdy plow to handle what I assume is a gravel 1/3 mile drive. A light duty "half ton plow" would get beat to crap on a long gravel drive.
20FT X 20FT ALL STEEL CARPORT (A58214)
20FT X 20FT ALL...
2017 Mitsubishi Mirage G4 Sedan (A56859)
2017 Mitsubishi...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2021 Deere 333G (A53317)
2021 Deere 333G...
2016 PETERBILT 579 DAY CAB ROAD TRACTOR (A54756)
2016 PETERBILT 579...
2019 International MV607 28ft Reefer Box Truck (A56858)
2019 International...
