Questions about attachments
/ Questions about attachments #1
mjdtexan
Houston(ish) Texas
Case IH 1140 (first tractor ever)
When one has bought himself an old Ford 8n or a Case 1140 and he wants attachments does one have to get one made by that tractor maker? Or, are attachments sort of universal ifin you stay in the correct implement class?
Please be aware that I am NEW to tractors (currently trying to decide between a Ford 8n and a Case 1140---so far) and I am probably going to need things explained in detail if very techinical. I
/ Questions about attachments #2
I dont know what class attachment the Ford or the Case you are looking at have(prob. a Cat. 1) but if they do,just about any Catagory 1 attachment should fit.
Example-Over the weekend i lent my neighbor my King Kutter boxblade
to do his driveway.His tractor is a 1967 Oliver 550 I beleive.My tractor is a 2007 Kubota B26.Japanese tractor vs. American, 40 years difference and guess what?It still fit with no modification because they are both catagory 1 hitch tractors.Great is'nt it?
There could be exceptions to the rule,i dont know.But to the best of my knowledge,a cat. 1 is a cat. 1 and a cat. 2 is a cat. 2. If its the same catagory,it should interchange regardless of the manufacturer.
digger2
/ Questions about attachments #3
Both use standard Category 1 attachments (had to Google the Case)
An 8N was my first tractor, still have it. A good, though basic, starter tractor.
digger2
Thank Yall both. I do appreciate yalls knowledge
/ Questions about attachments #5
They both are Cat I hitches. You dont have to get brand specific equipment any cat I equipment will work.
A list of equipment you can use:
brush hog - 5'
rear blade - 5' -7'
plow - 2 bottom 12"
finish mower - 5' or 6'
post hole digger - any
disk - 5' - 7' depending on soil conditions
tiller - not recommended becuase of ground vs. pto speed
Also any PTO equipment you use you should definately use a over running clutch which has been said before.
So on average you can use anything fro 5-7 ft wide. If you are not sure just ask that is what this site is for.:)
brush hog - 5'
rear blade - 5' -7'
plow - 2 bottom 12"
Thank You Sir. Great Site
/ Questions about attachments #7
Hi
Just remember that it is very handy to have some sort of a quick attach system to interchange attachments. that may not be of interest to you, but worthy consideration.
by the way,
check out our website for a great attachment for land clearing.
Star Hill JAWZ
thanks
john lyddon
Three posts on three threads all pitching your product...plan on a visit from the BOSS about advertising on TBN...;)
/ Questions about attachments #10
The older tractors may have an odd sized PTO shaft. There are adaptors you can get, but those can add alignment problems depending on the length of the pto shaft.
If you move up from the 1950's to a tractor from the 1970's you won't pay much more, but will get a LOT of better features. Like rear axle lock, more gears, better engines, stronger hydraulics, etc. I would target a ford 2000, 3000 or 4000 series with the 3 cylinder diesel engine.
jb
/ Questions about attachments #11
As JB said.. unless the 8n has had a pto shaft change.. it may still have the oem 1 1/8 6 spline shaft and not the 1 3/8 modern 6 spline shaft.
An overrunning coupler will fix the splines dimeter issue and make a mower safe-er to run on the tractor.
sounduy
/ Questions about attachments #12
sounduy
I thought most of the 8n's came with the larger shafts? I have replaces a few in the 9n's and 2n's but never in an 8n.
/ Questions about attachments #13
ALL the 8ns came with the small shaft. There was a 'SAE shaft upgrade.
The small shafts were still being used into the NAA model, post 8n.. I have an NA witht he small shaft.. etc..
soundguy
/ Questions about attachments #15
Actually, some of the early 640's had the small shaft too. Least ways, a buddy has one with the small shaft, a 1955 640.
jb
/ Questions about attachments #16
Ditto that...I've also seen early 55's with the small shaft.. etc.
soundguy
2007 Chevrolet Silverado 3500HD (A60462)
2007 Chevrolet...
Case 1083 20ft Corn Head (A63118)
Case 1083 20ft...
2010 Massey Ferguson 2625 (A60462)
2010 Massey...
LEEBOY 8515R ASPHALT PAVER (A62129)
LEEBOY 8515R...
2016 WANCO WTSP PORTABLE ARROW BOARD (A60429)
2016 WANCO WTSP...
Ford New Holland 8160 Tractor (A61166)
Ford New Holland...
