k0ua
Epic Contributor
SSQA is for sure more common here in the US for tractors up to 60 horsepower. I have never seen a Euro here for these small tractors. You do see it on larger tractors here.
The universal skid steer style quick attach will generally have two spring loaded levers at the top center of your loader arms. When you pushed these levers down, they will engage two pins vertically at the bottom. With the euro global style, you will only have a spring loaded lever on one side of the loader arms, not the top. This lever will engage pins horizontally, left to right, to secure the attachment. I have attached pictures of the back of two of our pallet fork frames. The skid steer quick attach system would be the best option as it is very quick and easy to connect. You will also find very competitive pricing on any SSQA implement. View attachment 497912
I run the JDQA, which is kinda similar to the euro global in operation. No handle but two drop-pins to secure. As I stated, I've had no problems getting implements to fit my QA and the OP won't have a problem either with whatever system he chooses.
Yep. In my neck of the woods your search for used attachments to fit the JDQA is very limited.![]()
Thanks for clearing that up Mate... it means that you're still going to have to get off your arse and physically dis-engage/lock the implement you're switching from/to.
