Quick connect jumper cables
   / Quick connect jumper cables #41
What you think happens when you CRUSH the wires in your crimp ?
   / Quick connect jumper cables #42
Either method will work - when crimping; however, it is important to use the correct crimper and die set.
   / Quick connect jumper cables #44
Refer to Anderson Connectors website
Crimping
This refers to crimping and soldering but note specifically
"NOTE: Underwriters Laboratories (UL) requires the use of a cable clamp for soldered connections to unsupported leads."
Unsupported leads tend to flex and are weakened at the junction with the solder. There is no such requirement to support crimp connectors.
Weedpharma
   / Quick connect jumper cables #45
weedpharma is right, a crimped connection for terminals is usually superior to a soldered connection.
25+ years ago I worked in a nuclear power plant, soldered connections were not allowed, they had to be crimped.
To form a proper crimp the entire end of the wire and the crimp barrel are basically cold welded together in a homogenous, gas tight "lump" with zero gaps.
Now that being said 99% of us don't have the correct tools to do a proper crimp.
So soldering is ok for non critical, as in not aerospace, marine or nuclear, connections.:thumbsup:
   / Quick connect jumper cables #46
We have a shop in town that deals in just batteries and related items. If I bought all the stuff from them I'm bettin they'd do any crimps for free.
2018 MQ POWER WHISPERWATT DCA-25 GENERATOR (A58214)
2018 MQ POWER...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2014 International PayStar 5900i Flatbed Truck (A55973)
2014 International...
1998 REINKE TRAILER HEAVY HAUL TRAILER (A58214)
1998 REINKE...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
