Quick way
   / Quick way #1
Jesse masterson
Platinum Member
Thebes il
07 kioti dk 45s
WHats the quickest way in a emergency to kill a dk 45 if switch or other mechanical failure, put blockage over air breather?
   / Quick way #2
PUt into high gear, low throttle, hold brakes and let off clutch has worked several times for me unintentionally. It ought to work when you want to do it too.
   / Quick way
That would work with my old tractor but I have hydrostatic tranny on this one.I should have mentioned that, sorry.
   / Quick way #4
High range at an idle, put the pedal down. Should be enough to kill er.
   / Quick way #5
There should be a manual fuel shutoff on the engine block in the vicinity of the injection pump. If that doesn't work (for example if the injection pump rack is jammed) I'd pinch, crimp, or cut a fuel line. You should be able to pinch off a fuel line with a vicegrips and not do permanent damage. You might also be able to strangle it with a plastic bag over the air cleaner intake but that may damage the air cleaner housing.
New Holland WorkMaster 37 (A53317)
New Holland...
2010 MAXEY WELDING 20 T/A GOOSENECK TRAILER (A58214)
2010 MAXEY WELDING...
1996 Sunflower 1543-38 Folding Disk (A56438)
1996 Sunflower...
2002 FORD F-350 XL SUPER DUTY FLATBED TRUCK (A60430)
2002 FORD F-350 XL...
FORKLIFT (A56857)
FORKLIFT (A56857)
Mini Skid 6 Way Blade (A56438)
Mini Skid 6 Way...
