Quickie log-drag, (paper-thin MIG weld)
   / Quickie log-drag, (paper-thin MIG weld) #41
I'd use a wire rope come along, with slip hook on the wire rope. Two wraps around the log, clip the hook on the wire rope with bail of hook facing tractor, and working end of come along at top of picking frame.;)
   / Quickie log-drag, (paper-thin MIG weld) #42
10' chain will handle a 30" log depending how much tail you need to get on your implement and how close you can get the tractor.
I have an 8' and 12' with slip hooks for skidding. 12'er mainly helps when I can't get close enough. Then I have chains with regular hooks to extend with if needed.
I have four 20 footers. Every time I go out I wish i'da cut one into a couple 10s, always forget to do it when I get back. This post is my reminder.
   / Quickie log-drag, (paper-thin MIG weld) #44
For a quick way to shorten chains, make up a couple of these and keep one in your tractor tool box.
Terry
Thats great, thanks! Saves me the pain of 'cutters remorse'.
   / Quickie log-drag, (paper-thin MIG weld) #46
Terry
I don't know why I never thought about this - but I'm sure glad you did :D
Thanks for posting :thumbsup:
I'm constantly picking stuff up with chains that are too long and have to be wrapped to take up slack.
   / Quickie log-drag, (paper-thin MIG weld) #47
Well, darn! That is a pretty good idea! I am going to make one of those.
   / Quickie log-drag, (paper-thin MIG weld) #48
So simple! Thanks for sharing Terry. Gonna make me one too! :thumbsup:
   / Quickie log-drag, (paper-thin MIG weld) #49
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=422579"/>
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=422583"/>
Terry
If your skills are up to it, you can weld two weld-on hooks back to back. Much smaller, could even fit in a pocket. Just be sure the weld is sound. Or you could cut a similar shape out of steel.
   / Quickie log-drag, (paper-thin MIG weld) #50
Or, pull the pins holding them together and hook the two clevises together. You will need to replace the pins with a grade8 bolt that is just long enough to have the "shoulder" for the whole clevis area.
Aaron Z
Haha Dan that sounds like a challenge! It should be arranged such that it's a long weld in shear. Welded from both sides (and wrapping the ends) it's pretty easy to make it stronger than the chain. A 3/8" plate with a 1 1/2" hole, and two slots ( like the planet Saturn ) would do it too.
Lots of ways to put that together, and I will certainly get a few of those setup. Thankful that Terry thought of mentioning it, I will definitely put some of these in my toyboxes.
Here's another simple unit ( called a "clevis claw") that you could pin to a link, and less likely to get lost.
What about just carrying a single grab hook and positively attach it to the chain where needed? Same idea as the clevis claw above, but a simple grab hook. Where you replace the cotter pin with a spring clip, or just bend the cotter such that it acts like a spring clip. Of course those small parts can be lost out in the woods.
Or if you want another 'link' can use an eye grab hook and this double clevis link
Lots of devices available, heres a bunch of them from Grainger
One bolt thru all four clevis holes, thats a good way. Using a nyloc too. May have to grind the clevises a little but yep that's an easy way to do it. or Clevis hook and eye hook together - not sure if these actually fit but I will find out this morning at the store.
   / Quickie log-drag, (paper-thin MIG weld) #53
One bolt thru all four clevis holes, thats a good way. Using a nyloc too. May have to grind the clevises a little but yep that's an easy way to do it. or Clevis hook and eye hook together - not sure if these actually fit but I will find out this morning at the store. <img src="http://www.tractorbynet.com/forums/files/welding/422710-quickie-log-drag-paper-thin-h5-16_med-jpg"/> <img src="http://www.tractorbynet.com/forums/files/welding/422709-quickie-log-drag-paper-thin-eye-grab-hook-aisi-316-a"/>
I tried it that way originally and it will work,but for me, I found the flexibility with the few links in between made it a little more "user friendly".
(And I'm not a very friendly user:(. )
Terry
   / Quickie log-drag, (paper-thin MIG weld) #54
I like this idea best so far.
The "Sodo-saturn link".
I have some chains that the links don't give you enough room to attach anything except at the ends, so that cool clevis claw wouldn't work.
Agreed you want to be able to turn the 2nd grab hook any which way to engage. In cases where you want to pull up all the chain tension you need to be able to rotate it any which way. Terry your original is a good way!
I like that the saturn unit:D can slip in a back pocket, 'cept my wife will kill me when it goes thru the wash.
   / Quickie log-drag, (paper-thin MIG weld) #56
But the trouble with the Saturn plate is you have to take time to stuff all the excess chain thru it. I think the original may be the best and quickest.
   / Quickie log-drag, (paper-thin MIG weld) #57
You guys are needlessly over-complicating this -
bungee cords are nearly ALWAYS the right length
:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:
   / Quickie log-drag, (paper-thin MIG weld) #58
I thought everyone knew about chain shorteners. :)
I walked out the the tractor shed to take inventory.
The one on the right was factory made.
Bruce
PS: The third one may not qualify, but is good for hooking something besides a chain to a chain.
   / Quickie log-drag, (paper-thin MIG weld) #59
Bruce
Nope, but I do now!. I bought the stuff and made one today. I had to buy a foot of chain they would not sell any less.:eek: I made him cut me 3 links though.:)
Grab hooks (3/8" size $3.99 for 2) atHarbor Freight. With 1 foot of chain you can make a couple shorteners.
The 1/4"size $3.49/2 will "grab" 3/8 chain (pay attention to your loads!!) but the clevis only fits up to 5/16" chain.
Eagle Weathervane (A55853)
Eagle Weathervane...
2019 Ford F-350 (A55973)
2019 Ford F-350...
2021 CATERPILLAR D5 LGP HIGH TRACK CRAWLER DOZER (A52709)
2021 CATERPILLAR...
2011 SOUTHWEST  GOOSENECK (A58214)
2011 SOUTHWEST...
5ft Pull-Behind Rotary Tiller Tractor Attachment (A59228)
5ft Pull-Behind...
Kubota KXO40-4 (A53317)
Kubota KXO40-4...
