R/F WHEEL LOCK UP
   / R/F WHEEL LOCK UP #11
That was my repair. Very easy to do. I almost missed the damage because it is hidden inside the large gear. Do not be afraid to open it up. Let us know what you find.
Ron
   / R/F WHEEL LOCK UP
Sorry it took me sooo long to get back to everyone, had a hard time loging on. Ok what your telling me is what I was afraid of. /forums/images/graemlins/crazy.gif I will tear the front end down as soon as the weather alows me to, and will post my findings. Thanks for your input and direction on what's needed to correct this problem. Till later play safe..
   / R/F WHEEL LOCK UP #13
Any roller bearings in there that might have let go causing binding / extra parts circulating?
Soundguy
   / R/F WHEEL LOCK UP #14
Sounds to me that Rick and Greg are on the right path. Not only going out of sinc, but a broken tooth getting caught between the miter gears, stopping operation. Makes sense when you back up, you are dislodging it and it falls from between the miter gears, allowing operation again until next time it finds it way between them.
Assuming this to be the case, I would start with the inspection of the right wheel gear mechanisim, as a broken tooth in the front differential would likely cause both wheels to lock up instead of just the one.
   / R/F WHEEL LOCK UP #15
put it in 4 wheel drive and raise the front end. Turn off the tractor. Rotate one front wheel and then the other, The opposite wheel should rotate the opposite direction. YOu are feeling for any roughness, catching, or locking up.
Ron
   / R/F WHEEL LOCK UP #16
</font><font color="blue" class="small">( put it in 4 wheel drive and raise the front end. Turn off the tractor. Rotate one front wheel and then the other, The opposite wheel should rotate the opposite direction. YOu are feeling for any roughness, catching, or locking up.
Ron )</font>
That is the best idea of all !! it would only take a few moments to see where the problem is. Great idea. /forums/images/graemlins/smile.gif
   / R/F WHEEL LOCK UP #17
That is how I narrowed down my problem. It is now posted on John's site.
Ron
2008 Nissan Sentra Sedan (A51694)
2008 Nissan Sentra...
2016 R and R Products 331 LP Reel Mower (A51694)
2016 R and R...
2014 Chevrolet Tahoe SUV (A52377)
2014 Chevrolet...
2015 Jeep Compass Latitude SUV (A53424)
2015 Jeep Compass...
2014 Triple Crown 10ft S/A Utility Trailer (A51694)
2014 Triple Crown...
UNUSED (2) 30PCS Grey Metal Roof Panels (A53117)
UNUSED (2) 30PCS...
