R1 or R4?
   / R1 or R4? #21
Wow, I disagree wolc123, I have had both types and there isn't that much difference in traction. On a 4720 with 17.5x24 R4 or 13.6x28 R1 they both pull well. The R4s' will hold a lot of Rimguard.
Steve
I agree, in fact this is a point that I have made more than once.
Around 55 gallons for your 17.5Lx24 R4s about 39 gallons in the 13.6x28 R1s.
Lower ground pressure too, as evidenced by the fact that the recommended pressure for the R4s is about 2/3 of that for the R1s.
I am NOT convinced that R1s give better traction than R4s when loaded, in fact I suspect that they more easily create the ruts in which traction becomes the problem.
Again, lawn/turf ripping is much more about sharp turns on wet ground than tire tread pattern, especially if you have a loaded loader on when you make those sharp turns.
The front wheels just PLOW, whatever their tread.
My compromise is BOTH; loaded R4s and unloaded turfs, I swap at the beginning of summer and right after the gardens are turned under.
I keep saying I will add a set of R1s "one day", but whenever the opportunity comes up (a set available and I have the money ready) I don't feel the need.
   / R1 or R4? #22
R1's hands down give better traction. I pulled out a stuck dozer with my 28HP tractor that a Dmax diesel failed on and then a 48HP R4 equipped tractor.
Like said before how many farmer you see running around on R4's?
Chris
   / R1 or R4? #23
What kind of soil do you have? We have blackland here. When blackland is wet - R4s ball up into a total mess while R1s clean themselves nicely. I have R4s on my 4520 cab and R1s on my 5525. When it is wet - the 5525 gets used. Cleaning all the mud out of the wheel wells of the 4520 is a serious hassle.
I have never had a lack of traction with my R4s on my 4520 or my old 4720. My issue has been mud.
I was worried about R1s tearing up my yard. I have driven across my yard multiple times with both the R1s and R4s. The reality is if it is wet - either one will screw up the yard.
I recently added wheel weights to my tractors. 2 plates on each side. They make a HUGE difference with loader work, etc. The tractor is much more stable when moving round bales around, etc.
Take your soil into consideration and consider adding weights.
D.
   / R1 or R4? #24
Farmers are doing mostly Ag work and a lot of us aren't. Farmers aren't mowing lawns or large tracts of finished grass and when my farmer friend got over his head and couldn't get out of his driveway he asked me to blow the snow drifts for him. My tires were R4s.
It's about application. Each has a purpose and its limitations, like any machine. If you do designing you find that out right away as I have.
Basically, you don't eat with a pitch fork and you don't pitch hay with a dinner fork.
Each tire has its pros and cons. Decide what yours are. That's why they sell different tread designs.
Rob
   / R1 or R4? #25
One of the first things a newbie should learn is when to stay off the tractor if conditions are too wet. You can do more harm than good.
From what I have surmised of the OP's needs is that if he is using the tractor for add chores both on and off the lawn that the R4's would be good choice. If he is rarely driving over the lawn then R1's would be fine. Neither tire would be a deal breaker for me.
Steve
   / R1 or R4? #26
Both tires are excellent, but for different conditions. In West Virginia, where it rains in the summer and the ground was soft, R1s were a must. Especially on steep hillsides. Now in California where it is dry 3/4 of the year and my ground is hard the R4s get better traction. If tire lugs can't sink in and grab the larger R4 tire patch is better. Also the R4 is much tougher and I do a lot of work in the woods where there are hidden tire rippers. If I were working ag land here I would get R1s.
Steve
   / R1 or R4? #27
I have sandy loam MOSTLY, the rest is roots and rocks - Oh YEAH I got ROCKS !.
If I had clay, blackland, gumbo, etc. I might have gone for loaded R1s.
I could get a set with rims and RimGuard for about $700 or $800, so it isn't about money.
Around here dealers seem to get asked for R4s the week before or the week after delivery, so R1 "take offs" with 10 minutes to 10 hours of "wear" on them come up quite often.
   / R1 or R4? #28
I might want a set of R1 take offs for my 4520. How much are they selling for anyway?
D.
   / R1 or R4? #29
D.
My guess is $700 to $800 for something in the 12.4 to 13.6x28 range, but I don't know EXACTLY what size tires go on a JD4520 - or what JD dealer mark-up is, or if they can give them to you at clear out cost, etc.
A lot would depend on your relationship with the particular dealer.
   / R1 or R4? #30
Yeah riiiight! Thats why you see R4's on farm tractors. :rolleyes: R1's have it hands-down in the traction department.
If you go back and read my post you will see that I said, "R4's are a good compromise between traction and the destruction they leave on the ground", meaning you get more traction and more destruction with R1's, but less traction and less destruction with R4's.
I said R1's are best suited for cultivation work, which 99% of the time that's what farm work is, whether your growing crops, haying, etc, it's mostly spent in a field.:rolleyes:
Next time, think your answer through in your head before you crap it out onto the screen.
2016 Godwin CD150M 6in Dri-Prime Pump S/A Trailer (A54811)
2016 Godwin CD150M...
40ft 10-Door Shipping Container (A52377)
40ft 10-Door...
MURRAY PUSH MOWER (A53843)
MURRAY PUSH MOWER...
377789 (A51573)
377789 (A51573)
2018 MACK CHU613 DAYCAB WINCH TRUCK (A53843)
2018 MACK CHU613...
2015 Toyota Prius (A53424)
2015 Toyota Prius...
