R4 Tire Choices
   / R4 Tire Choices #11
</font><font color="blue" class="small">( <font color="blue"> The Titan R4s on the front of my B7800 are showing obvious wear after only 250 hours. </font> )</font>
Are you doing a lot of hard pulling that would cause the tractor to spin or are you running in 4wd on hard pavement ???Do you operate on hard surfaces regularly ???
Just curious as to what would cause excessive wear on your tires ?? I am hard on my tires(R-1's), but I do a lot of log skidding on hilly terrain...Generally the r-4's should wear pretty good...I have a set of R-4's I use for spares...
   / R4 Tire Choices #12
That's what I have on my Kubota 4330. With no problems or complaints and I am just up the road from you, over here at Walnut. Luck be yours neighbor........teddy
   / R4 Tire Choices #13
</font><font color="blue" class="small">( The Titan R4s on the front of my B7800 are showing obvious wear after only 250 hours. )</font>
THAT is really strange, i have well over 350 hours on mine and they look like new. I only use 4wd when necesarry and very seldom on hard surfaces, except when plowing snow. How do the back tires look?
   / R4 Tire Choices #14
I wonder if the tires might be towed out or in too much.
   / R4 Tire Choices #15
For me, 4WD is a necessity for almost everything. The rear tires are Goodyears and look new.
Most of my hours have been accumulated in brush hogging, which tends to be tough going due to the fast growing, dense vegetation and hilly terrain.
   / R4 Tire Choices #16
Aloha,
My b2910 has only 125 hours on it and the fronts are obviously worn as well. In my case it is due to most of those hours being loader work. At first I was improperly using my hst and letting the front tires spin a lot by mashing harder on the hst pedal. I found that I just needed to let up on the pedal a little bit and I got more torque and very little spin. But the damage was already done. The bar edges are all rounded off and there are several cuts in the tread.
So it is possible to have tire wear on the front with low hours. By the way, my back tires look almost new.
   / R4 Tire Choices #17
I checked with Goodyear, and they insist that a radial R4 will vastly gutperform the bias versions normally supplied on new compacts. Significantly more money, however.
jim
   / R4 Tire Choices
I have attached a picture of the exact Titan R4 tire I purchased with my new L3830.
Lawrence
   / R4 Tire Choices #19
You must be planning on moving a lot of that red clay around you have in McComb ? I've spent more than a few days just up the road in Brookhaven.
John Mc
2008 JLG SKYPOWER 800AJ MANLIFT (A51242)
2008 JLG SKYPOWER...
20' Sea Container (A50774)
20' Sea Container...
UNUSED FUTURE SKID STEER QUICK ATTACH LAND LEVELER (A51244)
UNUSED FUTURE SKID...
UNUSED FUTURE 32" HYD TILT MINI EXCAVATOR BUCKET (A51244)
UNUSED FUTURE 32"...
2015 JCB 930 6,000LB 4x4 Rough Terrain Forklift (A50322)
2015 JCB 930...
DeeZee Crossover Aluminum Truck Tool Box - Secure Weather-Resistant Storage for Pickup Beds (A52128)
DeeZee Crossover...
