Traction R4344 - split brakes and traction lock
   / R4344 - split brakes and traction lock
Try this: jack up one rear tire off the ground, place range selector in neutral, 4x4 disengaged, ENGINE OFF, and try rotating the wheel by hand. If you have gear problems you should be able to feel it. You can also play with the diff lock while the wheel is off the ground, get an idea how it engages / disengages.
thanks Mike - great suggestion.
i had it up on jacks this weekend to put water ballast in the tires.
mine is a gear drive and not HST. the shifter was in neutral but range was in "4" - the shuttle was engaged in the forward position. 4x4 was off. i did not notice an gear troubles or noise when rotating the wheels to get the valve stems to the top.
it was still somewhat stiff to rotate the wheels around but that might just be because i weigh +/- 130# and have Muppet arms...
i did not think to test the engagement of the traction lock while i had it up. i'll try that this weekend when i use it to work on my old truck project.
ben
2018 Bobcat T190 Compact Track Loader (A55302)
2018 Bobcat T190...
1994 INGERSOLL RAND SD100D PADFOOT ROLLER (A52706)
1994 INGERSOLL...
2020  FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A52576)
2020 FREIGHTLINER...
2018 Chevrolet Silverado Pickup Truck, VIN # 1GB4CYCY6JF173260 (A54865)
2018 Chevrolet...
2021 M&J PRESHRED 4000M SHREDDER (A53426)
2021 M&J PRESHRED...
2008 CATERPILLAR 725 OFF ROAD WATER TRUCK (A51406)
2008 CATERPILLAR...
