radiant heat question in slab
   / radiant heat question in slab
Yes I have taken pictures just have not had a chance to post yet
   / radiant heat question in slab #13
I used 2 inch of PS insulation in my basement and garage. Then used the PEX on top of the insulation and used clips to hold down the tubing. The cement was reinforced with fiberglass so no wire mesh was used.
   / radiant heat question in slab #14
   / radiant heat question in slab #15
</font><font color="blue" class="small">( Yes I have taken pictures just have not had a chance to post yet )</font>
Michele, so you have already installed your tubing?
   / radiant heat question in slab #16
   / radiant heat question in slab #17
<font color="red">I read not to put near toilet, the heat will melt the wax donut</font>
Fernco now makes a rubber gasket that glues to the toilet bottom & is a snug fit into the toilet flange eliminating the wax ring. made specifically for heated floors. Found it at Home Depot with the wax rings. I'll never use a wax ring again.
   / radiant heat question in slab #18
   / radiant heat question in slab #19
Don't even think about using bricks, pieces of wood, etc. for holding your rebar up. They will absorb water, expand, and cause the finished concrete to crack.
The only proper things to use are professional rebar chairs, or what is called a dobe (pronounced "dough-bee") around here. The dobe is a small cube of concrete with tie wire in one face. The wire is wrapped around the rebar and the dobe spaces it off the ground. They are cast in flats, looking sort of like a tin of muffins, and are very inexpensive. They have the same properties as the concrete you are pouring and will not cause it to crack. I have seen 1 1/2 inch and 2" sizes. You will need a larger size for the top layer of bar, and if you can't buy them you can make them, once you have seen the smaller ones.
   / radiant heat question in slab #20
Deere 331G (A53317)
Deere 331G (A53317)
2019 Dodge Grand Caravan Van (A59231)
2019 Dodge Grand...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
Kubota B2301 (A53317)
2015 Toro Sand Pro 5040 Bunker Rake (A59228)
2015 Toro Sand Pro...
UNUSED FUTURE FT20 EXCAVATOR (A52706)
UNUSED FUTURE FT20...
