radiator leaks into oil
   / radiator leaks into oil #21
That's just like the little workhorse that I owned for 5 years. It was a sweet running tractor.
   / radiator leaks into oil #22
More parts sources for your Shenniu:
US & Canada Sales
2150 Eastern Ave.
Gallipolis, Ohio 45631
740-446-0813 or 740-446-9777
If you ask for sevice, these boys have a wealth of knowledge about this tractor.
Another dealer
H&W Tractor
Red Bay, ALA
1-800-445-3943
Another dealer
Jerry Third
Box 249
Hythe, AB
TOH 2C0 (Canada)
403-356-3019
Bluechip, took a look at this tractor and found another freeze plug on the inside of the engine that had come out.
   / radiator leaks into oil #25
YEp, screwed up a good sale on a brand new engine! Just kidding, glad it came out to be so much less than expected.
There are three freeze plugs under the tappet cover plates, inside the engine. Now we know, these three freeze plugs saved this engine.
   / radiator leaks into oil #26
sorry if im seen to hijack this thread, but i dont want to start a new one for a simple question
how does one know if their engine is dead after having it freeze up. so far, water in oil, oil in water, loss of water
anything else, what about the head gasket (water in the cylinders? how do you tell?)
thanks
   / radiator leaks into oil #27
I stand corrected . I did not know they had freeze plugs located on the inside of the engine block . Thanks for sharing this information . As a old dog ,I guess I did learn a new trick today !
Big Al
   / radiator leaks into oil #28
That's great. I was just thinking, it had to be a bigger opening than a crack or blown head gasket would be. Where in the engine was the third plug located?
(2) 300 GALLON POLY TOTES (A51248)
(2) 300 GALLON...
2016 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2016 Ford F-550...
BESTWAY AG VSK50 LOT IDENTIFIER 96 (A53084)
BESTWAY AG VSK50...
1982 GOOSENECK 24FT TRAILER (A52472)
1982 GOOSENECK...
FRONTIER LP2196 LOT IDENTIFIER 101 (A53084)
FRONTIER LP2196...
