Radiator Pressure
   / Radiator Pressure
I will flush it out tomorrow and see what happens. I still can't figure out why it doesn't run hot.
Eugene
   / Radiator Pressure
OK guys, you'll never believe this. I finally flushed out the cooling system. The radiator was not stopped up. The block was, with rust. Looks like someone ran straight water in it before me. When the rust broke loose I had full flow. I let it run in the driveway for 30 minutes with the overflow hose out of the bottle. Not a drop. Put the hose back in the bottle and instantly started blowing coolant out of the vent hole. Took the hose back out, it stopped. I did this repeatedly with the same results. I can touch the block bare handed and not get burned. Is my tractor haunted?
Eugene
   / Radiator Pressure
Eugene
   / Radiator Pressure #15
"Put the hose back in the bottle and instantly started blowing coolant out of the vent hole."
What vent hole are you referring to? The only vent I am aware of should have the overflow tube attached to it.
   / Radiator Pressure #16
   / Radiator Pressure
The vent hole is in the cap of the overflow bottle.
Eugene
   / Radiator Pressure
Eugene
   / Radiator Pressure #19
Assuming your 16# cap is good, sounds like you may be back to a bad head gasket. Something is creating high pressure in your system.
   / Radiator Pressure #20
2009 Mariah SC23 23ft. Cabin Cruiser with T/A Boat Trailer (A51694)
2009 Mariah SC23...
2001 XL SPECIALIZED XL 80 MDE DOUBLE DECK TRAILER (A53426)
2001 XL...
2014 Ford F-150 Ext. Cab Pickup Truck (A51692)
2014 Ford F-150...
Unused 2025 Wolverine SBM-12-72W Sickle Bar Mower Skid Steer Attachment (A51691)
Unused 2025...
CFG Industrial SAII100 (A50123)
CFG Industrial...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A51694)
2006 iDrive...
