3-Point Hitch Raising and lowering mid mount mower without moving 3 point hitch?
   / Raising and lowering mid mount mower without moving 3 point hitch? #1
rick480
On a BX 1860 is there any way to raise and lower the mid mount mower without raising and lowering whatever is mounted on the 3 point hitch? Other than pinning the lift arms to the stationary tabs. I need to hold my grass catcher attached to the hitch stationary, and lined up with the PTO while still being able to raise and lower the mower.
   / Raising and lowering mid mount mower without moving 3 point hitch? #2
I have the b2920 but would think they are similar. At least on mine the 3 pt is what has to move the MMM up and down. You can lock the MMM in up position and then you can move the 3 pt. down. but can't lock the 3 pt. and move the MMM.
   / Raising and lowering mid mount mower without moving 3 point hitch? #3
Never mind. Read the OP's post *fully* and he already recognizes it. No better answer though.
   / Raising and lowering mid mount mower without moving 3 point hitch? #4
So the answer is No. You cannot keep the 3 pt. stationary while raising and lowering MMM.
   / Raising and lowering mid mount mower without moving 3 point hitch? #5
What catcher are you using? The Kubota ones are designed with fixed attachment points.
David Kb7uns
   / Raising and lowering mid mount mower without moving 3 point hitch? #6
Put a receiver hitch on the drawbar, then mount your grass catcher to a long 2-inch square bar as a receiver insert. Build the mount so it lines up with the PTO.
Here is one commercially made for the BX, but some standard automotive ones fit with a bit of hole filing.
Kubota BX Fixed Draw Bar Extention - OMNI Mfg LLC
Bruce
   / Raising and lowering mid mount mower without moving 3 point hitch? #7
It sounds like I have the same issue. I have a cyclone rake and I made an adapter to put it on my 3pt.
I just got used to pinning the 3pt arms to the fixed mounts. Its easy because the grass catcher isnt heavy.
Its the only thing I have found inconvenient on my bx1860, but the 2 machines weren't designed to work together so I am just glad there is a way to make it work.
Here is my solution, I simply hung the 3 point arms from chains attached to the fixed mounts. Allows the mower deck to be adjusted yet holds the grass catcher firmly. This is a universal 3-point PTO driven grass catcher I bought new on EBay for about 1/2 the cost of the similar Kubota one. I'm very happy with it so far.
2000 GMC C7500 SINGLE AXLE VOCATIONAL TRUCK (A56129)
2000 GMC C7500...
2010 Freightliner Derrick Digger (A55973)
2010 Freightliner...
2013 Fiat 500 Sport Hatchback (A56859)
2013 Fiat 500...
8" Wilton Vise (VISE ONLY) (A59076)
8" Wilton Vise...
2020 INTERNATIONAL MV607 26FT CDL REQUIRED BOX TRUCK (A58017)
2020 INTERNATIONAL...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
