Raspy
Veteran Member
- Joined
- Dec 16, 2006
- Messages
- 1,636
- Location
- Smith Valley, Nevada
- Tractor
- NH TC29DA, F250 Tremor, Jeep Rubicon
My first set of factory Transforce 275s were pretty much shot at 19,000 miles. I then went to Toyo AT2 in the same size. Real good tires and I have run a number of sets of those on my other truck too.
Then I went to a set of Toyos in the 295 size. But they could not get them balanced. Discount tires tried four times at different shops and they were still not right. So I went back and told them to take them off and refund my money for defective tires. They did and I got a set of Michelin defenders in 295/70/18.
These are wonderful tires. Very long lasting, absolutely round and smooth running. Will carry any load the truck is capable of. They aren't aggressive off-road tires, but have been excellent for everything I've done.
The only problem was the gearing. In my thinking, the truck was already geared to high with the 3.42 ratio. With the bigger meats, it was annoying to drive, would not pull anything in 6th, was always hunting for gears. Sixth became useless with any towing, headwinds or slight grades, and I would just lock it out most of the time.
So I re-geared to 4.10 and fixed it. Perfect gearing. Now 6th, with the taller tires, is just a little higher than 5th was with stock tires. Again, perfect. 1st is more aggressive, the truck runs up through the gears better, 6th can actually build boost and pull reasonable grades and there has been no noticeable drop in mileage. In fact, it may have improved a bit. The truck has about an inch more ground clearance and the tires fill the wheel wells better.
