deerefan
Veteran Member
Mine is a SRW one ton. The 3/4 and the SRW one ton are very similar, except the one ton has rear leaf springs, an available HO tune with the Aisin, a slightly higher tow rating and some minor programming differences, like setting the TPM anywhere you want without getting a warning. I'm sure the one ton rides stiffer, as mine was brutal when I got it. But the axles, brakes and gear ratios are the same. Not sure if 4.10 is an option in the one ton SRW, or not. If so, it is the right option. I would have picked the stick, but didn't want to give up 200 ft lbs of torque.
Might be a dumb question-can you get the 1 ton with a 6 ft bed?
