Ram 2500 4x4 Cummins-opinions
   / Ram 2500 4x4 Cummins-opinions #21
How are they on reliability, especially with all the emission stuff? My biggest concern is high dollar repair bills after warranty expiration.
As the diesel evolves so do the emissions. All emissions are now downstream of the engine and in the exhaust except for a bit of EGR. Mopar offers MaxCare extended factory warranties if that makes you more confortable. I have a 120,000 mile 8 year MaxCare on my 3500/Cummins.
I think the gvwr was 12.5k. One thing I discovered-3.42 axle ratio. Was hoping for 3.73.
With the Cummins, the 3:42 is good up to about 17,000 pounds of tow weight. I have a 2015 3500 Cummins and tow several trailers, the heavist is the RV at 15,000 pounds. Never did I feel a need for more power. I can easily find 70 MPH on the accelation ramp to a freeway.
   / Ram 2500 4x4 Cummins-opinions #22
Don't let the naysayers turn you off from a dodge cummins. The Cummins is a legendary bulletproof motor. Smooth power and lots of it! The truck that surrounds the motor is wonderful as well. No comparison to the bad reputation they used to have in the 70's-80's. I have had inthe last 10 years a 91, 95 and now a 2014 all 2500 cummins 4x4's. All wonderful trucks and as much as I like the looks of the new Ford SuperDuties, I will stick with my Ram Cummins!
We have decided we both like the truck, looks great. I feel the only way to match the Tundra in longevity is to go diesel. I do/will pull some loads, 2-4 times a year, that creep into the 10k lb area, which is right at the limit for the Tundra. We are down to working price now, we are a couple thousand apart. We will see.
   / Ram 2500 4x4 Cummins-opinions #24
I've been looking to buy a new truck for over a year now. This will be the second most expensive thing I've ever purchased aside from the house, so I'm doing more than due diligence in research. I can't speak from experience but I can speak from long hours behind the screen reading other's experience. My research indicates that the Cummins they are putting in the Rams is the best diesel pickup engine currently on the market. The transmissions they are putting in the Rams, is not. The best transmission can be found in the GM trucks with the Allison transmission. Also the Ram trucks have suffered in recent years with poor quality plastics. Ram, GM, and Ford have all really upped their game in past few years. They all have their high points and low points, but none of the low points are low enough to be deal breaker and none of the high points yield a clear winner. It's a really tough call. I lean toward Ram one day, Ford the next. But 4 days out of the week I lean toward the Duramax. And then some weeks I spend swearing off the diesels entirely. While the "Big 3" have been spending so much time and money to improve their diesel game, they've been spend as much time improving their HD gasser game, and the EPA has been doing their damndest to make the cost of ownership of a diesel no longer make sense for anyone except those who tow heavy trailers for a living. Don't go straight for diesel without giving the gassers a fair evaluation. The HD gas trucks can tow nearly as much, cost less, and cost less to operate.
One last note, if you do get the Ram, let me know if it comes standard with an invisible trailer hitched to it. It seems like once someone buys a Ram, they lose their ability to drive down the road without the tow mirrors sticking out into oncoming traffic.
   / Ram 2500 4x4 Cummins-opinions #25
Got to be the dumbest thing I see on a daily basis
   / Ram 2500 4x4 Cummins-opinions #26
When I had my Ram with the tow mirrors I used to flip them out ONLY when towing. I realized the trailer I was towing wasn’t wide enough to even need them so I stopped flipping them out. When you do flip them you have to readjust them which is probably why people leave them out, to lazy to adjust them back. The correct term for it is “ghost trailer”.
   / Ram 2500 4x4 Cummins-opinions #27
That Cummins won't even realize that 10k load is back there.
Went up to Oregon to pick up another load of firewood a few months ago. Usually, I do this in the fall and the wood is dry but this load offered for a great price and I bought it even though the wood was pretty green - wet and heavy. The truck pulled it easily but I noticed that the exhaust brake wasn't doing as well as it usually did and I had to touch the brakes a time or two coming down off the mountain passes. So when I got to Burns Junction I ran across the scale. Truck, trailer and load were just shy of 30,000 lbs. My rig is a 2004 which listed as having only 505 ft-lbs of torque. A new 2018 has over 900 ft-lbs. Piece of cake!
   / Ram 2500 4x4 Cummins-opinions #28
My 2016 Ram has been a great truck so far with 40,000 miles.Time will tell.My 2004 Ram 2500 diesel 5.9 was flawless.
   / Ram 2500 4x4 Cummins-opinions #29
Don't get me wrong, I don't have any problems with the ram. I like yours, I would drive it. I still haven't ruled it out as my next truck. I was just pointing out some of the data and Ram has taken flak for weak auto transmissions for several years now, and they are still using the same transmissions. One thing I like about the ram is it's one of the only trucks you can still get with a stickshift. If it weren't for the fact they de-tune the engine by a couple hundredd ft-lbs in the manual version, I would probably already have one. They also have a PTO option that the other guys don't offer.
   / Ram 2500 4x4 Cummins-opinions #30
Explain same transmissions? Both of mine have been flawless pulling heavy loads.
2015 Ford F-550 4x4 Knapheide Service Truck (A51692)
2015 Ford F-550...
Heavy-Duty D-Ring Shackle Set (A53117)
Heavy-Duty D-Ring...
2007 Sterling Acterra Dump Truck (A51691)
2007 Sterling...
2017 Mack GU713 Granite Tri-Axle Dump Truck (A51692)
2017 Mack GU713...
2018 MACK CHU613 PINNACLE DAY CAB (A53843)
2018 MACK CHU613...
2015 Freightliner M2 106 Terex BT2047 10-Ton Crane Truck (A51691)
2015 Freightliner...
