Ram1500 EcoDiesel V6 revealed!
   / Ram1500 EcoDiesel V6 revealed! #701
It's about diesel stAtus instead of cost per mile.
Next a chrome exhaust stack, big tires and a lift kit.
A lot of money to make up for having a small male organ.
Not that I have ANY desire to be "more European" but this is one thing I do think they got right. They have far more diesels over than per capita than we do. I believe the reason isn't ALL mpg, although that is a good one, but the driving power they produce, at lower RPM's. To me lower RPM's equals longer engine life.
I believe as production numbers go up, in all categories, the cost to add a diesel will go down and make them more compatible, if not surpass gas engines. From where I sit, and have been doing my own research, diesels are just really coming onto the USA scene and are becoming cleaner and more powerful. The cost of gas engines is on the rise as well. The new direct injection engines require the same technology as diesel engines, ultra high pressure fuel pumps, high pressure injectors and to develop the power to compete with bigger engines, turbos and their related controls.
Historically, turbo gas engines do not hold up as well as turbo diesel engines. I'm glad to see more options come around it makes car buying more interesting.
   / Ram1500 EcoDiesel V6 revealed! #702
I didn't realize you operated your light truck and passenger car at max rated rpms and max HP 24/7 like an irrigation pump.
Around here engine rebuild shops are going out of business as they are not highway engines to rebuild. Way back in the days of carbs and leaded fuel. Valve jobs and 75,000 miles and complete overhauls before 100,000 miles were the norm.
Now lets move up to 2014!from the 1960's, 1970's and mid 1980's where you are stuck.
Gassers now make 300,000 miles with boring regularity, better than emissions diesels.
The vehicle frame and chassis is worn out and corroded away by then.
This talk of extending engine life for light highway vehicles is not longer a consideration.
We are not talking about the virtues of a 900rpm medium diesel on a ship propulsion system or gen set vs an 2500rpm LPG irrigation engine.
   / Ram1500 EcoDiesel V6 revealed! #703
I'd say it's a wash between diesel and gas. Diesel engines have been saddled with emissions controls, hurting mpgs and power. They cost more to build, buy, and maintain. They also cost more to feed daily. But they still provide more torque than some gas engines, and better mpgs than some gas engines.
Gas engines have really been improved in power and torque over the years, raised to diesel levels in some cases. They get better mpgs now too, but not as high as diesel. These higher tech gas engines now cost somewhat closer to a diesel engines, but cost much less to feed daily.
If you plan keep your truck for only a few years, you'll be paying dearly for a diesel up front, and you can hope the resale value will let you recoup some of that expense.
If you plan to keep it for 10 years +, then you'll probably break even on the up front expense of a diesel.
If you tow a LOT, then diesel tips the scale and wins due to the high mpgs while towing.
In the end, It will cost all of us about the same, no matter which engine we buy.
   / Ram1500 EcoDiesel V6 revealed! #704
Well if you insist on being rude and insulting, all I can say is your whole comment was pointless at the least. NO ONE said anything about running any engine wide open, nor did I say all gas engines wore out fast. I specifically said BOOSTED gas engines. Show me some stats on THEIR longevity before you come off so rude the next time. The Ford Ecoboost is the first of it's kind in a truck, that is meant for actual hauling. Unlike the supercharged 2 door models they have offered in the past, that are built for immature NASCAR wannabees. By the way, where are all those supercharged hot rods? There have been turbo cars and supercharged trucks in the past, but none of them have shown longevity. Sure normally aspirated engines live a long time, but any type of supercharged gas engines have had short road lives.
   / Ram1500 EcoDiesel V6 revealed! #705
Here are some Lightnings with over 100k on them. That is a lot of miles for a truck that lives it life a 1/4 mile at a time.
Used Ford F150 - Regular Cab Pickup in 22625 Area - on Cars.com
   / Ram1500 EcoDiesel V6 revealed! #707
I have to disagree. Many imports such as BMW and some domestic makes like Buick and Ford make turbo and supercharged cars for years. The run fine well into the 300,000 mile range or better.
Chris
   / Ram1500 EcoDiesel V6 revealed! #708
Haven't looked at Volvos much have you? Volvo has had turbocharged engines in their cars since the 80s and its not uncommon to see them with 200-300k miles. Dad had a '98 S70GLT with a turbo. It was over 215k miles when it met with a telephone pole and the turbo seals were just starting to weep a little.
No, they aren't boosted to the level that the EcoBoost is, but like the EcoBoost, they were built from the ground up to have a turbo on them, so they last and last.
Some links to look for yourself:
http://www.volvoclub.org.uk/miles.shtml
http://jalopnik.com/5892129/why-do-car-collectors-drive-1987-volvo-740-turbos
http://volvoforums.com/forum/volvo-850-16/anyone-ever-taken-high-mileage-850-vacation-60942/
http://www.matthewsvolvosite.com/forums/viewtopic.php?f=1&t=49717
Aaron Z
   / Ram1500 EcoDiesel V6 revealed! #709
As you mentioned, the ecoboost is too new to have and longevity data to prove either side of this argument. Same can be said about this new 3 liter diesel.
The Ford Lightning was before my time but I sure wouldn't have been immature to have wanted one. Also I hate NASCAR but enjoy being immature behind the wheel sometimes so you demographic profiling isn't 100% accurate.
One must realize the older boosted motors were typically modified normally aspirated motors which I agree would have had a shorter lifespan. Hopefully the newer specifically designed engines prove to be equal.
   / Ram1500 EcoDiesel V6 revealed! #710
Not to pile on here.... but boosted gas motors are as reliable as their NA counterparts. RPM is what kills a gas motor. The additional loads on a boosted motor are all compressional, which the rotating assembly can deal with very easily.
The ecoboost got in trouble with their intercooler design, which was introducing accumulated condensation into the motor resulting in broken parts and destroyed catalytic converters.
2019 MDB FM180 FINISHING MOWER (A51247)
2019 MDB FM180...
2018 Ford Explorer AWD SUV (A55853)
2018 Ford Explorer...
2003 Big Tex 10PI...
JOHN DEERE CT322 SKID STEER (A52707)
JOHN DEERE CT322...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2018 Ford F-150...
2014 Mack CXU613 T/A Wet Kit Day Cab Truck Tractor (A55852)
2014 Mack CXU613...
