Ramsplitter 3 point log splitter
/ Ramsplitter 3 point log splitter
I was a little weary about those issues, and TBN was a great source of information. I am just happy that the cycle time and force are better than I expected. Going this way saved me quite a bit of money, and the tractor does not seem to be any worse for it. Also, I'm just running out of space to store all of these devices I own that take oil and gasoline and filters:)
/ Ramsplitter 3 point log splitter #22
I don't have any remote hydraulic hook ups. Can I run a splitter using my FEL connections? I don't see why not but wanted to check with you all. Thanks!
/ Ramsplitter 3 point log splitter #23
Probably,
Does any of your levers have detent? You could run some hoses to the back and QD to the log splitter. You could put the log splitter on the front and use , say the curl circuit, if you can get the lever to stay open flow. Does your log splitter have it's own valve?
/ Ramsplitter 3 point log splitter #24
Just an additional note on the rapid extend valves by Prince. They say not for use on the two stage pump, used on log splitter. Does anyone know why?
A couple weeks and a couple cords later. All is good.
/ Ramsplitter 3 point log splitter #26
rjkobbeman -
Some folks bungee or tie their remote valve open. Some (myself included) have a detent on the remote valve so it stays open on its own. Others have an unvalved loop they tie into on the back, so there is no remote valve to deal with.
-rus-
have a 20 three point splitter from ram splitter I changed it to electric with a 3 hp electric motor it is in side. I am going to order a 30 ton three point splitter and run my princes pump. On it but I have to talk to Doug first. You won't go wrong with dogs stuff later
New/Unused Landhonor Quick Attach Receiver Hitch Adapter (A65583)
New/Unused...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A63688)
2023 Unverferth...
(APPROX. 128) 1"X6"X8" PONDEROSA PINE (A64281)
(APPROX. 128)...
2009 Jaguar XF Sedan (A61574)
2009 Jaguar XF...
2023 Chevrolet Express 2500 Cargo Van (A61573)
2023 Chevrolet...
2022 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A61573)
2022 Chevrolet...
