Ran out of pressure, dirty water from well.
   / Ran out of pressure, dirty water from well. #11
I said it was something like purging. I haven't got my owners manual yet, but I think it was called conditioning the well, and I said it was from water coming from the veins around the well, what you called the recovery water. They said it was a good thing to do on occasion. Maybe it was wrong. I figured somebody else must have read it too.
   / Ran out of pressure, dirty water from well. #12
We have the exact same problem. I saw the spec sheet on my well which says it pumps at 11 gpm but only replenishes at 2 gpm and has about a 500 gallon capacity. This works fine for the house but I can't water the grass as it will start pumping sediment after about 45 minutes. We ended up putting a cyclone filter where the water comes into the house to keep any sediment out in case we ran it too low and resigned ourselves to not watering the yard. Not a big issue for me as once the grass was in......only the strong survive!! /forums/images/graemlins/wink.gif
Jeff
   / Ran out of pressure, dirty water from well. #13
You should set your pump up so it will pump at a rate lower than the recharge rate.
Different size pump?
drill holes in some of the rotors?
restricting orfice on outlet - globe vale will work for this
Egon
City of Buckhannon Onan 450 Set Stand By Generator (A52384)
City of Buckhannon...
2023 JACTO JATAO-1000 LOT NUMBER 70 (A53084)
2023 JACTO...
2015 HINO BOX TRUCK (A52472)
2015 HINO BOX...
2011 Crown Victoria Sedan (A51694)
2011 Crown...
2016 MITSUBISHI OUTLANDER SPORT (A52472)
2016 MITSUBISHI...
