Ranchito clean up
   / Ranchito clean up #51
Bill 55 said:
Filimentious Algae. Tractor Supply sells an algicide that will pretty well kill it off. They also sell Aquashade to darken the water to keep it from growing.Neither are cheap but work well.I am working on my second gallon of the Aquashade so far this year. No ice cover and an early bright spring are hard on clear water ponds.Just follow the instructions on the bottle and you should be able to clear it up.
I imagine chlorine bleach would also take care of it.
   / Ranchito clean up #52
Bleach might kill it but if you don't darken the water it won't stay killed. Trust me. If let go it will totally cover the surface in a slimey 3 inch thick mass and eat up the oxygen and kill any fish that are there.
   / Ranchito clean up
Thanks, I'll look at TSC. what about the rye bales? Has anyone tried that?
   / Ranchito clean up #54
Rye is a good filler,and if lucky get some seed on ground when you feed it. Going for $50 a bale around here for 5x5's.
   / Ranchito clean up
A shot from the mailbox, the cleared land was all mesquite a short time ago. I finally picked up a subsoiler from TSC. Made 2 passes and stopped, I am going to have to wait till we get some rain.
Right now the plans are to plant sunflowers in that patch come spring. This has been horse pasture for the last 20yrs. I know that I will have to break it up. My plan is to first get the subsoiler going, then run the disc turning plow. I am hoping that the turning plow will cut and bring the mesquite roots up.
   / Ranchito clean up
Did a little digging around the pond. The drought is making it easy to make a bigger pond. I still have to put a slope on the ledges. But this is just the first stage let me know what you think and suggestions are welcome.
   / Ranchito clean up
Oops pic will not post
   / Ranchito clean up #58
Good to see some Texas boys on board!...nice place!...I have 13 trying to get the 5 next door now..ours is called the Sticks....
   / Ranchito clean up #59
Mozambique Tilapia will eat it and are sold throughout texas...put them in in may or when the water will stay above 60 degrees consistantly...the will eat the algae and are really good eating...will be eating size by aug or sept...they will die when the water gets below about 55 degrees so probably won't have an over crowding problem...cost about ten dollars a pound for fingerlings...recommend 2 -3 pounds for that size pond...
Rich
Ps...go to a forum called Pondboss.com great source of information on management of ponds...
Rich
   / Ranchito clean up
Thanks for the info, but how do they deal with bass? I have a few in there now that love to eat mice.
NEVER USED FECON 74in Deck Mulcher FDM74 (A52748)
NEVER USED FECON...
REYNOLDS 100 - 8 YARD PULL TYPE SCRAPER PAN WITH DRAWBAR (A52748)
REYNOLDS 100 - 8...
2016 John Deere Gator XUV560S4 4x4 Utility Cart (A50322)
2016 John Deere...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
2006 TerraGator 8104 (A52748)
2006 TerraGator...
John Deere Lift Arms (A50121)
John Deere Lift...
