Ratchet Rake/Brush pics
   / Ratchet Rake/Brush pics #11
I dont see that it can be flipped over not the way the mounts are welded up.
Should be able to have your local TSC order it in, just give them the SKU #
   / Ratchet Rake/Brush pics #12
It looks like the function of the top edge (forward pointing) is to cut the debris off, and the lower edge (down pointing) is to rake.
I really like the looks of it, but I'm afraid my area where I would use it the stumps will tear it to pieces...
Backdragging my bucket with toothbar or my root grapple is S L O W, but I'm not sure I have an option of using one of these...
I can clearly see how it is a great device though... And I want one...
Hmmm...
Be well,
David
   / Ratchet Rake/Brush pics #13
With my Kuboata b7200 I'll loose traction before I'll break or bend a tooth on the rake, even in 4wd, if the stump is too big. Ask me how I know. Lol
   / Ratchet Rake/Brush pics #14
One of my main concerns would be the durability of the straps. Seems as though if you were clearing heavy brush the straps would tale a beating.
   / Ratchet Rake/Brush pics #15
The one that comes with the unit does have a eye hook sewn on one end and a wire hook on the other end. Eye hook goes into the rakes tie down point, wire hook into the cable eye. It can easily be replaced with a 2" x 27' ratchet tie-down strap with wire hooks each end, sold for 10.00 to 15.00 depending where you are, just cut it down to length desired and add a shackle for the wire hook to hook into on the rake itself.
After all the brush, Mesquite limbs I removed/broke off....I think they will last quite awhile.Defintely will need to spray the ratchet with lube pretty often.
As far as bending breaking on stumps, I dont think that would happen. Well not on the 72" x 5/8" thick. I was pushing over Mesquite trees as big a tree as my tractor can break/push. Hit some stumps that stopped the tractor cold with no bending.
I did not have any problems with bending and hit stuff that stopped the tractor.
   / Ratchet Rake/Brush pics #17
#1 - Is it reversable? One side has smallteeth, the other larger.
Can you flip it over?
#2 - My TSC did not have a 72" in stock, do I ask them to order it for me?
Thanks,
David
I recently purchased a RR at my local TSC. The first time I attached it something did not look right. Sure enough I had it reversed. I looked at the pictures closer then attached it correctly. So it will reverse, but think the large teeth down is better. The angle of attack lets me run the teeth under what I want to root out then roll the bucket up. A back and forth action on rolling the bucket while slowy moving ahead with the tractor worked on rooting out some salt grass clumps.
It is actually more effective on roots back dragging it - or maybe I have not learned the finer points of operation. I used it to loosen up some compacted clay and then drug my box blade across the area to cut down a high spot.
It is easy to attach and detach. Drive onto the unit then roll the bucket up to strap it on. Just wondering how long the webbing will hold. It is on the heavy side. If your TSC does not have it in stock try to find out when the next "truck" is coming in. You may save a few dollars on freight if it is delivered through normal channels rather than special ordering.
   / Ratchet Rake/Brush pics #18
I got the RR after reading the reviews here 2 years ago as I had a lot of brush clean up work after stumping here in rocky NH.
Due to the embedded rocks (6" to 1' to ledge size) and various small stumps the RR did not really work out as planned. If would clog up fast with the 2' dia roots, and pine stubs, then the rocks would cause the loader to jump loosing the load in the RR. Then to spread loam out it needed to be dry - if clumpy or damp the RR would just make divots dragging the clumps of loam.
For grading / raking and root removal in non rocky or with brush less than 3" trunk this is probably a good tool.
Glad it works for others.. a york rake worked better for me at the end of the day.
Carl
   / Ratchet Rake/Brush pics #19
Hmmm...
Be well,
David
I have been studying these things for about 6 months. I too was intially concerned about stumps in the area I am going to clear with it.
But my local TSC got some in a couple of months ago so I actually got an up close look at them in the store. I have a 45 hp mahindra with ML260 loader and there is NO doubt in my mind that I will tear my loader up before I break this rake.
Santa is bringing me rachet rake !
   / Ratchet Rake/Brush pics #20
Finally got to use my new RR this weekend, works GREAT! Used on white brush/mesquite/cat claw/ prickly pear. It pulled most up by the roots, left some but considering that before I started this area was hard to walk through, much less drive equipment through. I am very happy with it and it will be one of the most used pieces of equipment I have bought. First couple of pics is before I started, the rest are after the rake. Worked it like the video on the RR website and no complaints, even killed a rattle snake with it!
Did it take you very long to get comfortable using it?
What techinique did you find worked the best ? Slow forward or back drag
Also what size did you get ?
I am getting one in the next couple of weeks so any information would be helpful.
30pc. 16ft.x 3ft. Black Metal Roof Panels (A53424)
30pc. 16ft.x 3ft...
Clark CGC400 Forklift (A54865)
Clark CGC400...
2006 Utility Trailer Trailer, VIN # 1UYVS13256P972701 (A53422)
2006 Utility...
Peterbilt (A51692)
Peterbilt (A51692)
2017 Freightliner M2 106 T/A 4,000 Gallon Water Truck (A55788)
2017 Freightliner...
2022 Club Car Tempo Cart (A55853)
2022 Club Car...
