RC-30 All Surface Loader
   / RC-30 All Surface Loader #11
Yeah, there are a few people with these units on TBN now. And I appreciate the comparrisons between different types of tractors...
Anyone got any more comparrisons between these units?
   / RC-30 All Surface Loader #12
Hey David
I really have nothing more to add other than to clarify that my comments were primarily for comparison of these machines to the PT - the machines (PT vs RC30 or RC50) are really very different with different applications but do cross over into PT territory with the "turf edition" -
I was pointing out was that in certain applications on turf - it may be a viable alternative vs a PT
for someone that still needs a very compact machine (like a PT) that will not tear up turf and does not have the weight of a construction trac machine (so you can trailer it) and the person needs tight turn capability - needs high lift capacity & height - dealer support - etc,etc.
Of course I pointed out that there is a cost for all of this - they are expensive -
For me (as an owner and lover of the PT) these units are very interesting because I had not encountered units (other than PT's and others like it) that would not tear up turf which was one of the most important factors for me in deciding on a machine.
So I thought it was important to make sure we got it correct when discussing the units performance on turf. We want to make sure our members are reading the best information we have according to our research.
With that all said - again the person making the decision on the PT when comparing to other machines as always needs to look at the application - I doubt you are going to MOW with this thing as most of us use the PT for.
Cheers
   / RC-30 All Surface Loader #13
I don't own them, but have used them. I have posted on it before, I believe in the "Buying" section.
I have used two skidsteers; the Bobcat S185 56hp turbo, and the Bobcat 463; 36" wide machine for limited access. I have used two track-laoders, the RC30 and Cat-247.
For dry stuff, the skid steers work great. A little wet, and they make a big mess. They can move large amounts of dirt or material very well. The 463 got me through a 36.5"' gate where I had to remove material and bring it around front. I have used the S185 for grading, moving material and running a trencher. The hi-flow trencher on that S185 CRANKS! it is impressive! About the S185 and wet conditions, it is parked at the house now(belongs to a buddy). I was moving dirt, and dumping it in a big hole on a slight downslope. I was running up and down the slope properly, but it tore things up fast with wet conditions. I got stuck and used the loader to pull forward; I could not back out. It got sideways on the slope and tippy! I had to finally use the loader to pull forward down the slope, while trying to straighten out. I did it, but it was not fun, and I had to drive way down the property to find a way out.
I have used the RC30 and Cat-247 for digging, grading, and loading a dump truck. The RC30 was a bit short for loading the 8yd dump truck; I had to make a little ramp of dirt. I did grading and digging in damp conditions where the Bobcats would have to be parked. It worked great, with little mess. The same with the Cat. I had to dig and grade in a back yard, and load a dumptruck out fron. Had to go across the grass... I loaded 8 8yd dumps using a 1/2 yard bucket, over wet grass. It did leave some minor indentation that will fix up easily. Man, a skidsteer of similar size woulda made a mess; would have had to park it.
The track-loaders had joysticks. I liked that. The steering control on the Bobcats has a long throw. It's easy, but you move more to steer and manuever. Bobcat does offer that option on many of its tractors.
Both track-loaders had ASV track system. The RC30 had the torsion suspension, not sure about the Cat. Boy, they rode much smoother than the skidsteer. The track loaders were nice to drive.
The RC30 could manuever pretty tight with standard tracks and not tear up the grass. I have seen the video on the putting green with the turf tracks; it is believable. The Cat, I did not manuever as much with it in sensitve area's. On the grass, I made a point to move straight forward and back, 'cause it was rather wet...
One note, with a local Bobcat dealer, they rent cheaper than the regular rental shops... I have not rented from the Cat/ASV dealer, although I noted thier price compared to the local rental shop. I could not justify the 45 mile pickup, and then delivery to go get it down in Sacramento. When I rented the Bobcat 463, and the Bobcat Hi-flow trencher, I was working not far from the Bobcat dealer.
I want to sell my B8200 Kubota and get a RC30. I need to save up the balance; the Kubota would be about half the price. I am looking at low hour dealer offers. Looks like a RC30 with 2-300 hours, with a clamshell bucket and trencher, would run about $22-23k.
My biggest worry is the price of putting a mower on it to replace the capabilty of the Kubota for mowing the property. I am thinking of selling the Farmall-A, and upgrading to a Super-A with 3pt.
   / RC-30 All Surface Loader #14
The Bobcat track-loaders run 7k-9.5k-lbs. T300 says 4.1psi. T180/190 are 5psi.
The ASV RC30 is 2.7psi; considerably lower when considering turf work. The RC50 is is 2.7psi also; not bad for a 50hp machine. The RC100 is 3.5psi.
I do not know anything about the PT's, except some folks here really like them /forums/images/graemlins/smile.gif
2013 MACK CXU613 (A53843)
2013 MACK CXU613...
Case 950 8 Row Air Planter (A53473)
Case 950 8 Row Air...
2018 MACK PINNACLE (A53843)
2018 MACK PINNACLE...
2014 MACK CXU DAY CAB (A54607)
2014 MACK CXU DAY...
2005 Nissan Pathfinder SUV (A53424)
2005 Nissan...
LAPTOPS AND ASSORTED POWER CORDS (A53843)
LAPTOPS AND...
