Re-Certifying oxy acetylene tanks in FL
   / Re-Certifying oxy acetylene tanks in FL #21
I used to own a lot of cylinders, but now down to almost a dozen or so. A couple are the "larger size" that appear to be 330 cu' but actually are just 251 cu'.
The "clean ring" often gives a clue but is by no means an absolute. Sometimes a larger bottle bears a gas companies name but has the right serial number prefix for a customer owned bottle. Sometimes size delegates c/o no matter what, while sometimes it is only part of the picture.
I suggest finding out bottle cu ft first, and then on to the next step...
David from jax
   / Re-Certifying oxy acetylene tanks in FL #22
Hazmat products are being clamped and have a paper trail that can easily be followed. I have checked with all local distributors. No one will fill a customer owned tank. One company did sell tanks years back and if you have the paperwork they will fill them but they must be recertified every five years at a cost of $65.00 / tank.
I have a lifetime lease, two of the largest capacity tanks available, for $500 including tax and free first fill. The bonus is I can release them to anyone and they will change ownership information .. or ... I can turn them in when done with them and get back 65% of the $500 lease price. It was the best deal I could swing so I did take advantage of their plan. They have a copy of the paperwork so I don't have to bring mine everytime I have them filled. My argon / oxy tank is a five year lease, $95.00 I believe. Again the largest tank and it takes $60.00 per fill. I may go with a lifetime lease with the other company when it comes due.
   / Re-Certifying oxy acetylene tanks in FL #23
wow.. robbery!
   / Re-Certifying oxy acetylene tanks in FL #24
Have to agree with you on that Soundguy!!
David from jax
   / Re-Certifying oxy acetylene tanks in FL #25
Just had my 60# owner owned acetylene tank 'swapped' out with a full one.
I still own the tank don't I ?
cost- $50
   / Re-Certifying oxy acetylene tanks in FL #27
Or could be like a friend who changes his empty from oxy to argon and back so he has a spare for whichever one of the other two is running the lowest or expects to be needed first. Most companies will switch contents, as long as the h/p bottle is the same for either.
David from jax
2006 WARREN 30' DUMP TRAILER (A54756)
2006 WARREN 30'...
White Metal Roof Panels (A55758)
White Metal Roof...
2008 OVERLAND TANK KILL TRAILER (A52472)
2008 OVERLAND TANK...
PREDATOR TRI-FUEL 13000 GAS PORTABLE GENERATOR (A54757)
PREDATOR TRI-FUEL...
2008 CATERPILLAR 12M MOTOR GRADER (A51406)
2008 CATERPILLAR...
2014 Toro Workman HD 07369 Utility Cart (A55851)
2014 Toro Workman...
