Rear end popping
   / Rear end popping #11
I had a popping in my 4240 sounded like lug bolts. I found out it was the front axle pivot was loose.
   / Rear end popping
Jack up the rear of the tractor and see if the wheels are free to spin separately to be sure the diff lock is not still locked in! When turning are the rear wheels digging in more then before?
I want to tell it seemed like tires were digging a little more than normal, but I can't say for sure.
   / Rear end popping #13
The diff lock foot engagement could appear to be released but could be partially engaged. The lugs on the diff lock could be rounded off semi-engaging the diff lock which would cause a knocking noise that is even and in cadence and rhythm to tractor speed.
As previously suggested, jack up tractor rears and see if you get opposing spinning.
   / Rear end popping
took the tractor to dealer and findings were that the differential was cracked and needed replaced. thank you guys for all your help.
   / Rear end popping #15
Thank you very much for the follow up. Too many times ppl post things here and then they disappear which helps no one beyond the conjectures. Follow ups solidifies the education for all involved.
   / Rear end popping #16
Thank you, my thoughts exactly.
2019 International DuraStar 4300 24FT Box Truck (A53422)
2019 International...
UNUSED 20 in. Gasoline Chain Saw (A53117)
UNUSED 20 in...
JOHN DEERE ROW MARKERS - SET OF STACK FOLD 12 ROW 30 INCH ROW MARKERS (A53473)
JOHN DEERE ROW...
2007 Ford Focus Hatchback (A51694)
2007 Ford Focus...
UNUSED 70PCS Black Metal Roof Panels (A53117)
UNUSED 70PCS Black...
DOOSAN G25 GENERATOR (A53843)
DOOSAN G25...
