Rear finish or MMM
   / Rear finish or MMM #31
Pictures of the property or the tractor? There pics in first post.
EDIT: Here is some better pics.
Personally, I think your looking at too little tractor and and too small a mower....
Take a look at an L5240 or L5740 with turfs and a 96" rear flail mower with an offset....
Regards,
Chris
Regards,
Chris
Wow thats a big. I don't know if my budget is going to allow for that unless I find a nice one used...Why do you say go for the L series? Weight? Power? Or the HP on the pto to drive a 96" RFM?
   / Rear finish or MMM #33
Doug,
I own a Kubota B2910.. It is the predessor to the 3030. It's a nice little machine.
The reason I reccommend such a large machine is because of all the factors weight, power, stability and the pure push/pull grunt power that a larger machine has.
You can get a smaller mower... mowing will take longer.... I think mowing with a flail mower will be faster than a rear finish mower but they weigh a lot more and they take a lot of hp to run.... a 96" unit will take 50hp . Also a flail will not bogg down if you let the grass get 12' high... 12" grass and a RFM is a no-go.
You will have a lot of open space out there and it doesn't look like you need a small machine.... and believe me a 3030 is small when your doing a job like that...
Regards,
Chris
Thanks for that insight. I'll seriously have to consider these factors.
EDIT: Holy crap thats an expensive setup... I certainly would not be able to afford even that tractor at base. What about something like the L3400, or L39 with a smaller flail mower?
   / Rear finish or MMM #35
EDIT: Holy crap that's an expensive setup... I certainly would not be able to afford even that tractor at base. What about something like the L3400, or L39 with a smaller flail mower?
Sure they would be good choices.... When you step from a B to an L it's a whole lot more machine. Unfortunately it's reflected in the prices.... Maybe there are some good deals on repos through Kubota credit....
Regards,
Chris
   / Rear finish or MMM #36
Great view.
It's philosophical here but everyone at some point in life needs to mow more than practicality would dictate if for no other reason than the life experience.
We need things to talk about when we get older.
Regards,
Chris
Repo's huh? Im seeing a lot of used L3400's. There no 52 horse but there also a little bigger than the B could offer. There are some larger models used...But used is used..
Where can you dins information on repo's?
   / Rear finish or MMM #38
Doug,
A repo is likely to be newer and may be low hours.... This is a buyers market so just don't buy anything that your not 100% happy with...
I would try contacting Kubota Credit....
In the end you can actually mow those fields with the 21" push mower... You wouldn't want to do it, but the other end of the spectrum is a 18' wide batwing mower...
The answer is somewhere in the middle, and like all the rest of us will be dictated by available budget.
I think you'll want a machine that weighs in at more than 3000 lbs, 35 to 50 hp has a loader that can lift in the 2000 lb range... and don't forget a suspension seat....
Regards,
Chris
Thanks, Chris. I never thought about repos. Ill check into it with Kubota credit. You are very right on your spectrum. I have a debate now between new vs used. With the 0% financing new is attractive, however I can get a lot more tractor used with low hours and only a year old. I like the idea of the flail mower and am going to look more into that as well. Right now, It's winter, so I have time to figure it out. I may just let the lower yard of grass grow out.
1972 Baker 30ft Pole S/A Towable Trailer (A51694)
1972 Baker 30ft...
More info coming soon! (A50322)
More info coming...
New Wolverine72 In Skid Steer Brush Cutter (A53002)
New Wolverine72 In...
2001 Club Car Carryall Utility Cart (A51691)
2001 Club Car...
2016 Dodge Charger Sedan (A51694)
2016 Dodge Charger...
2007 WABASH 53FT DRY VAN TRAILER (A52576)
2007 WABASH 53FT...
